DerekK
2002 R1150rt Clutch Replacement
DerekK
Hi All, New to the group.
I am getting ready to open up my R1150RT to grease the splines. Bike is currently at 33K. While I am in there, I figure I will do the clutch components. Do any have any experiences or recemmendations of anything else that maybe worthwhile along with any good techniques ? Any help is appreciated?
Regards
and Thanks Derek
Share this post
Link to post
Share on other sites
szurszewski
Just to be clear, you’re going to pull transmission just to grease the spines? Is there a reason you’re doing this?
Share this post
Link to post
AndyS
Hi Derek, Why are you going to rip the bike in half at such a low mileage?
You can see if you have a potential 'ticking bomb' by inspecting the gearbox input shaft backlash by viewing it through the starter motor hole (once the starter motor has been removed). If you would like info on doing this, please ask and we will furnish you with the appropriate information.
(I know yours is a 2004 but the same proceedure applies),
This is what DR wrote on another post [https://www.bmwsporttouring.com/topic/94383-new-to-me-r1150rt/
If you will be working on that 2002 1150 bike (I know yours is a 2004 but the same procedure applies),  you might remove the starter, then zip tie the clutch lever to the hand grip, then see if you can reach into the clutch area & rotate the clutch disk on the transmission splines (if you have significant  rotational play of clutch disk to input shaft then suspect that your clutch disk/trans input shaft splines are on borrowed time)  & spline  failure is in your future (this leaves the motorcycle totally without forward drive).
The 2002 1150RT was the worst offender for failed splines of the 1150 series. Obviously most didn't fail but a number of 2002 bikes did fail.
The time to address the possible failure is before it leaves you dead on the road far from home.
Share this post
Link to post
Jim Moore
I know everyone loves a winter project, but IMO you're wasting your time. You either have a good one or a bad one. You can determine that using Andy's method above. If you have a bad one you need to pull the bike apart and fix it. No amount of spline lubing will save it. If you have a good one, it's good for a quarter-million miles. There's no need to lube the splines.
Share this post
Link to post
DerekK
Awesome! thanks for feedback. The bike is driving great!!!.
I was applying logic that having to go in and grease the splines (for some reason I heard between 35 and 40K it was recommended , where I cannot recall.) I would do the upgraded plate to engage the splines. Had a couple of friends way back with the 02 model (like mine) that had the splines fail. I was thinking I would get out ahead of it. Always have been one to go above and beyond with maintenance. ( a little OCD with that respect :grin:) .removing the starter is a
 Andy, If you could send on that info it would be great. Removing the starter is a whole lot easier than splitting the bike and dropping $500+ in parts for piece of mind.
Regards and thank Derek
Share this post
Link to post
AndyS
To remove the starter:
https://www.manualslib.com/manual/911233/Bmw-R-1150-Rt.html?page=146#manual
Every other major service, I remove the starter motor and with a long pipette or very thin artists brush on an extension bar, I make up a mix of molybdenum disulphide powder and suspend it in IPA (alcohol). The I CAREFULLY brush / float it along the upper spline of the input shaft - 1 spline at a time - taking great care not to allow it to drip onto the clutch plate assembly. I rotate the gearbox round by putting it in gear and bumping the back wheel.
YOU DON'T NEED MUCH ON EACH SPLINE!
All of this is a token effort as the problem cannot be hidden. If you have a mis-aligned unit, it will destroy itself.
Like DR says, even if you took it apart, if you didn't put it back together exactly as you took it apart, you probably generate more problems than you solve.
I do not use grease, because it will not move along the shaft. The MOS2 powder suspended in IPA 'wicks' along the shaft and then the IPA evaporates off leaving the lubricating powder to do its work.
Take care not to allow the mixture to migrate down onto the clutch plate.
Share this post
Link to post
Lowndes
Derek,
While you are planning to remove the starter to view and maybe apply some moly to the splines, you might want to consider drilling a weep hole in the clutch slave cylinder housing.  The reason for this is that if/when the slave cyl fails the DOT4 will travel down the clutch rod and destroy the friction plate.  This weep hole can be done without removing anything, or you can back the cyl out to make sure you clear it.  This happened to me three years ago which required a complete clutch job.  Spare yourself the work.
https://goo.gl/photos/QEN3xyQVWXW1jraT6
https://goo.gl/photos/WB9DZXksFyRq5mPm8
Share this post
Link to post
Still CAL
Some interesting info, although six years old. Caution: PG21 due to some strong language, and last three minutes are dated info and probably don't apply anymore.
Share this post
Link to post
kioolt
I replaced my clutch on my 04 RT at 150k.  I can't imagine why you think you need to replace the clutch at only 33k.
Share this post
Link to post
ltljohn
I have the "Splinal Tap" tool for greasing the splines through the starter hole that was left to me by Mamma Hoon and KMG365.  I will gladly pass it along if you want it.  It is a syringe and a long needle to reach in and apply grease to the splines.    If you want it PM me your address and I will send it along.  Just pass it along if someone else needs it.  Info about the tool is in THIS THREAD
Share this post
Link to post
Lowndes
Esmir makes a clutch hub spline spacer kit to provide 100% spline engagement on stock clutche discs.  It does not work on the Seibenrock clutch discs because the rivet hole carcle is different but you could make one.  It is a simple steel spacer that is installed between the spline hub and clutch disc and comes with the extra length rivets.
Share this post
Link to post
DerekK
Thanks All, Belated Merry Christmas,
Finally got around to pulliung the starter off and looking in. There seems to be little to no play.
Apart from some dust (asssuming from the clutch) looks OK? It appears to be dry at least.
Can I ask if any off you have similar appearance from your bikes?
IMG_1896.thumb.jpg.8447e25395c1101c9523ff90b1e946e8.jpgIMG_1901.thumb.jpg.06de7d5d4b0fe90366f4d8897acbf8cf.jpg
Lowndes, Looked at the doing the weep hole, but the case of the RT prevents me getting good access to the housing to drill the weep hole.
Any input is appreciated
Regards
Derek
Share this post
Link to post
Jim Moore
Pull in your clutch and tie it off to the handlebar. Then look in that slot and use a long screwdriver to rotate the clutch hub back and forth. You're hoping the hub and that splined shaft rotate in unison, with little or no slop between the two.
Share this post
Link to post
DerekK
Thanks Jim,
Couldn`t really get much at the splines. Moving the Friction disk I get around an 1/8 of an inch at the outer circumfrence of the friction plate.
1st photo the is against the splines, rotating the plate downwards.
2nd photo is spline contact rotating upwards. You can feel a very slight amount of play when rotating the disk.
Hope this makes sense.
Share this post
Link to post
joeb
Hi. I have an 03 with 116k on it. no sign of slippage.  And , I dont baby it.
Share this post
Link to post
The Fabricator
2000 R1150GS 25000 miles.  My disc moves about double that amount.  I doubt the splines have been lubed by the previous owner{s}.
Lubing is on my list.
I think I will try the 'reach in' technique first, then evaluate before deciding whether to teardown or not.
Edited by The Fabricator
clarity
Share this post
Link to post
Jim Moore
1 hour ago, DerekK said:
Thanks Jim,
that's good, man. Just what you're looking for. Button it up and forget about it.
Share this post
Link to post
DerekK
Awesome, thanks Jim,
Share this post
Link to post
fatbob
Derek:
one thing you should do for this RT is replace the clutch slave cylinder.   It is old and when (not if) it fails it trashes your clutch.    Mine failed due to this at 54K last year.
Share this post
Link to post
DerekK
Fatbob,
Thanks , I am assuming that your slave cylinder leaked?
Thought about doing the hole drill but looking at how I gain access.
Regards
Derek
Share this post
Link to post
dirtrider
Morning Derek
The work around instead of drilling a hole in the case is to simply cut a slot in the slave cylinder gasket. That allows fluid seepage out of the slot. The 1200 bikes don't even use a slave cylinder gasket.
Share this post
Link to post
fatbob
There’s a good treatment of the weep hole drilling on this site.   You have to remove the swing arm and exhaust to do it.   It’s easy to replace the slave cylinder at that time too.   Yours is 18 years old, it is time!  Yes I lost a clutch due to leaking slave cylinder.
Share this post
Link to post
BobW03
Derek, et al., I had first hand experience with 'Affordable Beemer'. While I do accept the facts his videos are helpfull, he made me believe buying my 03 RT was gauranteed to have clutch issues. I brought it to him with 11k instead of the local BMW dealer. He went on a rant and showed me a failed clutch telling me I will have the same issues. There is a reason he only works on bikes up to 2004, he was a tech at a now closed BMW shop. Anyway I did pull my tranny at 35K and there was nothing wrong. Clutch plate was fine, no wear on the spline, etc. Just a lot of wasted time and effort for me. I even brought the tranny To MAX for verification by a tech. They replaced a seal on the tranny since I had gone that far. I am just an average shade tree mechanic but tackled that job. I sold the 03 with 68K miles and have bought an 11 and now a 16RT. My point is dont believe everything you see or read on the internet.
Edited to give credit to DR who has on multiple times aided me when I had a problem on my 03, some self-inflicted. DR is one person I would trust explicitly for advice
Share this post
Link to post
DerekK
Thanks DR and all,
With changing the exhaust Can, I got rid of the Catalytic converter, so thinking I might be able to get access from underneath. Might look to remove the slave cylinder, inspect and do the gasket mod at the same time. Anybody have experience of using Beemer Bone yard’s slave cylinder?
I have watched the Affordable Beemer guy, helpful, but certainly has His own bias for sure 😂.
Regards
Derek
Share this post
Link to post
taylor1
I bought a slave cylinder from BBY @ 60,000 miles ago. 3  bleeds and all is still good .
I also had a cat. eliminating exhaust on mine when I swapped it out. Can't remember if I took off the can or not.  Was a real pain , but doable.
If memory serves ,  I had to shorten one end of the Allen
Share this post
Link to post
fatbob
I bought the BBY slave.   Only have 1 year and 10K on it so can’t vouch for its longevity.    It’s easiest to remove the swingarm to replace the slave.   It’s good to adjust the Swing arm bearings and replace the FD pivot bearings with this operation.
Share this post
Link to post
