Dingo55 Posted April 23, 2023 Share Posted April 23, 2023 Hi All Any significant problems emerging on this particular model? Cheers Mark Link to comment
wbw6cos Posted April 23, 2023 Share Posted April 23, 2023 Hi Mark, The '19 - '20 models are essentially the same. On my '19 RT, I have 44,400 +/- miles and the only things that would be close to significant problems are the costs for tires, fuel, and brakes. On a more serious note, the exhaust flapper valve started making a loud squeaking noise when it cycled at ignition-on aroud the 6 k mile mark, but other than that, nothing else. The dealer looked into it and "applied some grease," but that did not last very long. After about several weeks, it started happening again. I eventually sprayed some lube in there myself when I do a service or change the rear tire. I use THIS spray lube. It lasts a lot longer; at least to the 6 k mile service. I spray it into the shaft of the butterfly on both the top and bottom and cycle the valve a few times. Hope your RT gives you plenty of iissue free miles. So far..... Cheers, 1 Link to comment
Dingo55 Posted April 23, 2023 Author Share Posted April 23, 2023 Thanks for that How widespread is this issue? Causes? Unburnt fuel? Climate? Can the valve be removed successfully ? Cheers Mark Link to comment
Dingo55 Posted April 23, 2023 Author Share Posted April 23, 2023 How problematic is it to not have access to the bmw tech info in regards to self servicing Cheers Mark Link to comment
wbw6cos Posted April 23, 2023 Share Posted April 23, 2023 17 minutes ago, Dingo55 said: Thanks for that you are welcome How widespread is this issue? unknown to me. Just something to keep an ear on. Not a big deal, really. Causes? Unburnt fuel? Climate? cannot say for certain. the bike gets ridden daily, every other week for commuting and BMWST events far and near. Can the valve be removed successfully ? not likely, as it is part (permanent) of the exhasust system, though I read somewhere online about someone bypassing that valve, but it siezed up on them. Doubt that happens a lot. I did not mean to alarm you about it. The issue, howver insignificant is is, was the only issue that I have experienced. Do a search on this forum about it. Quite a few state that it is normal on some bikes and they have learned to live with it. See my original post HERE. No worries. Cheers Mark 9 minutes ago, Dingo55 said: How problematic is it to not have access to the bmw tech info in regards to self servicing not very problematic if you can watch a few youtube videos. Allow me to introduce you to @Boxflyer and some of his beneficial servicing info - LINKY Cheers Mark Link to comment
Dingo55 Posted April 26, 2023 Author Share Posted April 26, 2023 Thanks for the info Much appreciated I have used Boxflyer's wonderful productions previously also very much appreciated Thank you Cheers Mark Link to comment
John R1250RT Posted May 9, 2023 Share Posted May 9, 2023 Hello William, Might want to give "Mouse Milk" a try. It's recommended to use on the gate of the turbo charger on one of my airplanes and it seems to work well. It's designed for high heat. John 1 Link to comment
MikeB60 Posted May 9, 2023 Share Posted May 9, 2023 Must be good. Although it's distributed through/from California you can't sell it there! 1 Link to comment
wbw6cos Posted May 9, 2023 Share Posted May 9, 2023 ....also, keep away from heat or open flame. 1 Link to comment
duckhawk64 Posted May 9, 2023 Share Posted May 9, 2023 How do they hook up the milking machine to the mice? 1 1 1 2 2 Link to comment
Chris K Posted May 10, 2023 Share Posted May 10, 2023 13 hours ago, duckhawk64 said: How do they hook up the milking machine to the mice? Here you go: https://www.facebook.com/simpsondankmemes/videos/milking-rats/372378423408479/ 1 Link to comment
John R1250RT Posted May 10, 2023 Share Posted May 10, 2023 That is crazy isn't it.... "It takes extremes of heat and cold," "keep away from heat or open flame." Oxymoron Apply it when the pipe is cold 1 Link to comment
dirtrider Posted May 10, 2023 Share Posted May 10, 2023 24 minutes ago, 56-100 MARY said: That is crazy isn't it.... "It takes extremes of heat and cold," "keep away from heat or open flame." Oxymoron Afternoon 56-100 MARY Not really, those type products usually have a somewhat volatile liquid carrier that evaporates after application. Once applied & the carrier flashes off then the actual lubrication part is probably fairly heat stable. 2 Link to comment
profbodryak Posted June 27, 2023 Share Posted June 27, 2023 Dingo55, I used a servo buddy on my '15 RT and it completely solved the issue. Luckily the default position of the flapper valve is when it's open, so install with the bike off. It will eliminate the error code (no check engine light) but keep the valve in the open position permanently. Link to comment
