JustPete Posted June 24, 2021 Author Share Posted June 24, 2021 Thanks. I do have some stainless in the garage here I can swap them out with. The brake job may be significant due to the current state of the front master cylinder. It appears to have leaked or dried completely out. A full rebuild will be needed on it I'm guessing, and hopefully the ABS isn't messed up. I live in SE Virginia around Hampton and Newport News area. Link to comment
taylor1 Posted June 24, 2021 Share Posted June 24, 2021 At this pace it sounds like you'll have it all buttoned up in time for FART Hopefully you can make it. Good Luck Link to comment
JustPete Posted June 24, 2021 Author Share Posted June 24, 2021 1 hour ago, taylor1 said: At this pace it sounds like you'll have it all buttoned up in time for FART Hopefully you can make it. Good Luck I had to look that up... Haha. I went through the posts from last year and it looks like a great time! I'll certainly try and make it. Link to comment
taylor1 Posted June 24, 2021 Share Posted June 24, 2021 Sorry Pete , I should have been a little clearer . Third down from the top . Fall Appalachian Riding Tour. You can get all of this falls info .A great time to be had ! Link to comment
RPG Posted June 24, 2021 Share Posted June 24, 2021 Glad you got it figured out and staying with it. Link to comment
Dave P Posted June 24, 2021 Share Posted June 24, 2021 Pete- yeah, when I switched out the brake lines I did a master cylinder rebuild at the same time. Figured it was time since the system was already opened up. Kind of a pita if I remember correctly. I never found a rebuild kit for the rear master. Dave Link to comment
