Bill Cats Posted Thursday at 01:21 AM (edited) 1994 BMW 1100 RSL - I blew the rear brake line today, the line from the rear caliper to the metal hose hook up right behind the rear brake peddle - It has a 10mm banjo fitting at a 45 degree on one line and the other side is a female fitting that the metal line screws into, In the past i got generic 10mm to 10mm banjo lines without any issues BUT i do not know the thread size on this fitting,,???? I see lines specified as 10mm banjo to 3/4 inch female..... ( is that it .... or ....? ) Thanks so much Edited Thursday at 01:23 AM by Bill Cats Share this post Link to post
dirtrider Posted Thursday at 11:17 AM 10 hours ago, Bill Cats said: 1994 BMW 1100 RSL - I blew the rear brake line today, the line from the rear caliper to the metal hose hook up right behind the rear brake peddle - It has a 10mm banjo fitting at a 45 degree on one line and the other side is a female fitting that the metal line screws into, In the past i got generic 10mm to 10mm banjo lines without any issues BUT i do not know the thread size on this fitting,,???? I see lines specified as 10mm banjo to 3/4 inch female..... ( is that it .... or ....? ) Thanks so much Morning Bill It's a German motorcycle built with metric parts so 3/4" anything doesn't sound correct. You have your old hose so just measure the fitting size & thread pitch. Share this post Link to post
Bill Cats Posted Friday at 01:00 AM After doing the research it's a AN-3 female connector with a M-10 female with a 1.0 pitch thread Share this post Link to post
Bill Cats Posted 20 hours ago Hey , just wanted to check back in with you and let you know i DID end up needing - 3265-18 Female 10 x 1.0mm Metric Concave Seat to 3AN Male, Steel 2 7.29 14.58 I only needed one BUT got 2 JUST because i have another line i want to cut over to standard AN-3 Thanks for your help and when it arrives ill keep u posted :))) Safe riding Share this post Link to post
Lowndes Posted 17 hours ago Bill Cats - have your other brake lines been replaced already?? Share this post Link to post
