Bud Posted May 12, 2006 Share Posted May 12, 2006 When I replaced the left front fork seal on my K1100LT I guess I didn't get the rear portion of the front fender tightened enough. It's now gone! Any thoughts on where I could find a cheap replacement? Link to comment
Firefight911 Posted May 12, 2006 Share Posted May 12, 2006 BMW Boneyard or backtrack last known roads and check side of roads. Link to comment
wrestleantares Posted May 12, 2006 Share Posted May 12, 2006 www.beemerboneyard.com www.cyclesrecycled.com (Fred is a cool guy and usually cheaper than Beemer Boneyard - and I get to save on shipping since he's local for me) Link to comment
Bud Posted May 12, 2006 Author Share Posted May 12, 2006 BMW Boneyard or backtrack last known roads and check side of roads. Been there, done that, now have found one online!!!! Link to comment
MysticRed Posted May 12, 2006 Share Posted May 12, 2006 Hey Bud, if you tighten those side screws on the rear portion of the front fender too much, it will compress the plastic (don't ask me how I know!) and then it will take some modification to get it to work. Just tighten enough. Nice K11, BTW. Link to comment
Bud Posted May 13, 2006 Author Share Posted May 13, 2006 Hey Bud, if you tighten those side screws on the rear portion of the front fender too much, it will compress the plastic (don't ask me how I know!) and then it will take some modification to get it to work. Just tighten enough. Nice K11, BTW. Hi, Thanks for the tip. I won't ask. Red is a great color. Link to comment
270 Posted May 16, 2006 Share Posted May 16, 2006 Ah, you guys make me miss my K1100's!! Don't get me wrong; I LOVE my 1150RT, but I sure miss watch the tach and speedo needles swing around the dials on those wide open space roll-ons! On the rear fender portion; try a nylon or mylar washer in front of the original washer. I don't know why they used a "slot" instead of a hole, but...it's really easy to over-tighten and squish the fender out, for sure. I small spot of lock-tite (blue, please) will give some added comfort against the bolt not feeling as tight as it should be. Link to comment
MysticRed Posted May 16, 2006 Share Posted May 16, 2006 Yea Tad Pole, these things pull like a train. You really only need 1st gear (to get started) and 5th. I used those star washers on mine as a repair, one on each side of the slot. Link to comment
bmwmick Posted May 16, 2006 Share Posted May 16, 2006 Hey Bud, if you tighten those side screws on the rear portion of the front fender too much, it will compress the plastic (don't ask me how I know!) and then it will take some modification to get it to work. Just tighten enough. Nice K11, BTW. Excellent color choice. Astral Blue? I used two small flat washers to actually add some surface to those slots. One washer on each side of the fender. I came all the way home from Canada one year with my fender banging into the radiator cover. Noticed it when I got home. Mick Link to comment
