R100R Rider Posted January 8, 2021 Share Posted January 8, 2021 In converting headlight to LED: do I need a load resistor? Link to comment
dirtrider Posted January 9, 2021 Share Posted January 9, 2021 12 hours ago, R100R Rider said: In converting headlight to LED: do I need a load resistor? Morning R100R Rider Maybe, depends on the LED load & your system's sensitivity. Try it without a load resistor, if you get a "LAMPF" or "LAMPS" showing on your dash then you will probably have to add a load resistor in parallel. Link to comment
R100R Rider Posted January 9, 2021 Author Share Posted January 9, 2021 Thanks dirtrider Link to comment
Hati Posted January 9, 2021 Share Posted January 9, 2021 7 hours ago, dirtrider said: add a load resistor in parallel. Usually you add resistors in series to increase resistance, so current draw increases, so monitoring is satisfied with the high enough reading. Am I wrong? Link to comment
dirtrider Posted January 9, 2021 Share Posted January 9, 2021 14 hours ago, Hati said: Usually you add resistors in series to increase resistance, so current draw increases, so monitoring is satisfied with the high enough reading. Am I wrong? Afternoon Hati Usually you add resistors in series to increase resistance, so current draw increases, so monitoring is satisfied with the high enough reading. Am I wrong?-- In a word, yes. He needs to add load so adding resistance in parallel does that. (he needs to DECREASE resistance not add resistance). Adding resistance in series would decrease the light intensity as the series resistor would act like a dimmer control. Link to comment
