dduelin Posted January 6, 2021 Share Posted January 6, 2021 This rubber grommet fits around the fuel filler hole opening. I don't think it seals against the bottom of the filler cap for ventilation and over filling reasons but maybe cushions/insulates the sharp edge of the fill hole from the gas nozzle inserted down in the top of the tank itself . On mine the bottom lip of the grommet has broken off and the part lies loose and is just fussy to deal with. It gets out of place or hangs on the gas nozzle tip and falls out on the ground. I am probably overlooking the most basic search but I cannot find the part in the Fuel Tank diagram of the fiche. The bike is an 07 with VIN ZT10166 build date 10/06. Link to comment
dirtrider Posted January 6, 2021 Share Posted January 6, 2021 15 minutes ago, dduelin said: This rubber grommet fits around the fuel filler hole opening. I don't think it seals against the bottom of the filler cap for ventilation and over filling reasons but maybe cushions/insulates the sharp edge of the fill hole from the gas nozzle inserted down in the top of the tank itself . On mine the bottom lip of the grommet has broken off and the part lies loose and is just fussy to deal with. It gets out of place or hangs on the gas nozzle tip and falls out on the ground. I am probably overlooking the most basic search but I cannot find the part in the Fuel Tank diagram of the fiche. The bike is an 07 with VIN ZT10166 build date 10/06. Afternoon Most riders just throw that darn thing out before it breaks off & the bottom part falls into the fuel tank. Or they are missing as they tend to stick on the filler nozzle then stay with the filling station pump. The early 1200 GS uses the same (or pretty close anyhow) nozzle limiter ring (most are gone by now) that was BMW part number 16117678016 SPACER. Link to comment
dduelin Posted January 6, 2021 Author Share Posted January 6, 2021 OK, sounds good to me. Link to comment
Rougarou Posted January 6, 2021 Share Posted January 6, 2021 Mine's been in the tank for a couple years,.....no issues yet Link to comment
