gr8mtn Posted December 19, 2020 Share Posted December 19, 2020 I am looking for a sweet mount that I once had on another '04. It replaced the clutch reservoir cover on my "04 RT. The only difference is that it had a little Ram Mount Ball on top of it. Very clean and looked factory. Scoured the web and no luck. Link to comment
dirtrider Posted December 19, 2020 Share Posted December 19, 2020 33 minutes ago, gr8mtn said: I am looking for a sweet mount that I once had on another '04. It replaced the clutch reservoir cover on my "04 RT. The only difference is that it had a little Ram Mount Ball on top of it. Very clean and looked factory. Scoured the web and no luck. Afternoon gr8mtn Every once in while you see one of those around, probably most are homemade by drilling the clutch reservoir cover then adding a 1" ball mount to the cover. I made one for myself back in the 1150 days but gave it away as I didn't like the off-center GPS location. If you are not using handlebar mounted mirrors you can add a longish 1" ball mount to the clutch reservoir mirror mount hole. Link to comment
