Riderdrumr Posted November 3, 2020 Share Posted November 3, 2020 This is on my 2015 R1200RT. I played with it before and after reading the manual but still can't get the time adjustment to set. When I adjust it in the menu area the clock on the bottom right corner does not reflect the adjustment. Anyone have any ideas? I tried this with and w/o the engine running. Link to comment
Skywagon Posted November 3, 2020 Share Posted November 3, 2020 Turn on your GPS in the cradle. Mine sync’s to GPS. The GPS knows the real time Link to comment
realshelby Posted November 3, 2020 Share Posted November 3, 2020 There is also a menu where you have to allow the clock to sync with the Nav system. Make sure that is on ( assuming you are using nav?). That will do all the clock adjustments for you. Nice when traveling through time zones... 1 Link to comment
92Merc Posted November 3, 2020 Share Posted November 3, 2020 I think once you've rolled your hour back, you have to push the wonder wheel to the right to "save" it. If you go left, it'll just back out the changes. I changed mine yesterday without issue. Link to comment
Riderdrumr Posted November 5, 2020 Author Share Posted November 5, 2020 On 11/3/2020 at 10:52 AM, Skywagon said: Turn on your GPS in the cradle. Mine sync’s to GPS. The GPS knows the real time That's it! Winner, winner, chicken dinner! Link to comment
