MagYukon Posted October 29, 2020 Share Posted October 29, 2020 Hello, I know many people are saying that a radio is irrelevent on a RT, but I'm still want to have one. My Idea is to add speakers as I don't have any actually, and a marine radio. The radio i'm thinking about is a Boss Marine radio which is only 3" in diameter x 5" depth. I'm wonderring if it might fit in the left side of the plastic panel. Actually, my RT is stored for the winter and I don't really have access to it. Can someone take some measurments for me ? I'd like to know how big is the platic cover and overall dimension of the left side (see picture below) Also, if someone have the internal space available at speaker location behind grill. That will help me to identify which speaker might go there. Thanks ! Link to comment
9Mary7 Posted October 29, 2020 Share Posted October 29, 2020 That is actually what I was thinking about this winter. I'll measure it tonight when I get home and let you know. 1 Link to comment
MagYukon Posted October 29, 2020 Author Share Posted October 29, 2020 25 minutes ago, 9Mary7 said: That is actually what I was thinking about this winter. I'll measure it tonight when I get home and let you know. Glad to know i'm not the only one with this idea Link to comment
Skywagon Posted October 29, 2020 Share Posted October 29, 2020 Are you wanting measurements of left side box. I can do it in next hour or so i think people who don’t like the radios are for a couple reasons. It’s hard to hear the speakers at freeway speeds. The BMW radio has an ancient BlueTooth hard to use connection, it doesn’t have a 3mm jack, and some just don’t want radios while travelling by bike I like having it and use it on every ride. I just wish they would make integration with BlueTooth and headsets easy. A 3mm jack is needed Oops sorry you have a different bike than me. My measurements won’t help. I just had a small picture on my cell Link to comment
MagYukon Posted October 29, 2020 Author Share Posted October 29, 2020 1 hour ago, Skywagon said: Are you wanting measurements of left side box. I can do it in next hour or so i think people who don’t like the radios are for a couple reasons. It’s hard to hear the speakers at freeway speeds. The BMW radio has an ancient BlueTooth hard to use connection, it doesn’t have a 3mm jack, and some just don’t want radios while travelling by bike I like having it and use it on every ride. I just wish they would make integration with BlueTooth and headsets easy. A 3mm jack is needed Oops sorry you have a different bike than me. My measurements won’t help. I just had a small picture on my cell It's not really a box, but yes I'm looking to the left side space. on a 2013 RT Link to comment
9Mary7 Posted October 30, 2020 Share Posted October 30, 2020 Ok...... So that space is only 3" wide at its widest. I don't see enough room for a 3' diameter mounting circle. But you do have me looking for another spot to put one. Link to comment
MagYukon Posted October 30, 2020 Author Share Posted October 30, 2020 I thought that 3" diameter would have fit in this space. The other option that I have find is: Bluetooth source: https://mbquart.com/powersports-audio/source-units/bluetooth-controllers/n1-wbt/ Amp: https://mbquart.com/powersports-audio/powersports-amplifiers/na2-amplifiers/na2-400-2/ pretty small form factor, but without any screen. As my phone is hooked on my handlebar with a Ram-X mount, it's not a big deal. Now, I have to find what speaker can fit in. My bike actually don't have any speaker, so I guess that the speaker "case" is not there also. Just putting speaker behind grill is probably not a good idea as there will be no box to guide sound forward. Link to comment
Skywagon Posted October 30, 2020 Share Posted October 30, 2020 Mag...Depending on your objective...If you are just interested in listening to the radio while riding, you can install a SENA 20S EVO or higher headset in your helmet. It has a built in FM radio. When I want to listen to FM I use the SENA as it gives better sound quality in my helmet than the BMW factory system with bluetooth. It will also likely be your least expensive option Another option for you if you already have a bluetooth headset..... it has am/fm/wx https://www.revzilla.com/motorcycle/jensen-jhd910bt-bluetooth-mini-radio?sku_id=1034871 1 Link to comment
BrianM Posted November 3, 2020 Share Posted November 3, 2020 On 10/30/2020 at 8:38 AM, MagYukon said: Now, I have to find what speaker can fit in. My bike actually don't have any speaker, so I guess that the speaker "case" is not there also. Just putting speaker behind grill is probably not a good idea as there will be no box to guide sound forward. Might see if you can find a foam speaker baffle that is small enough. Link to comment
MagYukon Posted November 3, 2020 Author Share Posted November 3, 2020 5 hours ago, BrianM said: Might see if you can find a foam speaker baffle that is small enough. that'S a pretty good idea. anybody knows the OEM speaker size on a 2013 RT ? looks like its 4", but not sure thanks ! Link to comment
MagYukon Posted November 13, 2020 Author Share Posted November 13, 2020 can someone tell me the size of the OEM speaker ? Thanks Link to comment
lkraus Posted November 13, 2020 Share Posted November 13, 2020 The main speakers and tweeters mount in housings that are attached to the bike. These are from a 2006 RT , but the part numbers are the same for the Camhead years. 1 Link to comment
MagYukon Posted November 16, 2020 Author Share Posted November 16, 2020 On 11/13/2020 at 11:17 AM, lkraus said: The main speakers and tweeters mount in housings that are attached to the bike. These are from a 2006 RT , but the part numbers are the same for the Camhead years. Thanks !!! Link to comment
MagYukon Posted January 27, 2021 Author Share Posted January 27, 2021 On 10/29/2020 at 12:30 PM, 9Mary7 said: That is actually what I was thinking about this winter. I'll measure it tonight when I get home and let you know. Hello 9Mary7, have you finally started your winter project ? I'm still planning mine but haven't decided anything yet. Let me know if you have some idea ! Thanks Link to comment
9Mary7 Posted January 28, 2021 Share Posted January 28, 2021 Still looking at options....... I'll let you know when I decide on something. Link to comment
