Dave P Posted October 29, 2020 Share Posted October 29, 2020 96 1100RT, poking around under the nose, this bundle of wires was taped off, not connected to anything. Bike has no radio (kinda like that) could this be wiring if it had the radio? Dave Link to comment
dirtrider Posted October 29, 2020 Share Posted October 29, 2020 9 hours ago, Dave P said: 96 1100RT, poking around under the nose, this bundle of wires was taped off, not connected to anything. Bike has no radio (kinda like that) could this be wiring if it had the radio? Dave Morning Dave Yes, part of the radio harness. 1 Link to comment
Artie John Posted November 13, 2020 Share Posted November 13, 2020 Which, if any of those wires are switched? Looking for a trigger wire for Denali fuse block. Link to comment
dirtrider Posted November 13, 2020 Share Posted November 13, 2020 17 minutes ago, Artie John said: Which, if any of those wires are switched? Looking for a trigger wire for Denali fuse block. Afternoon Artie The Violet wire is usually the switched one but you might have to put a fuse in cavity #8 in the under-seat fuse box for it to provide key-on power. Link to comment
RogerC60 Posted November 13, 2020 Share Posted November 13, 2020 I used the violet wire to power a USB phone charger. I discovered that the violet wire is hot with the key in the "R" position. I need to turn the key all the way to "OFF" to de-energize that wire, which also means locking the handlebars all the way left or right. Mine's an '03 and yours is a '97 so they might be different, but it's probably something you'll want to check. Link to comment
dirtrider Posted November 13, 2020 Share Posted November 13, 2020 21 minutes ago, RogerC60 said: I used the violet wire to power a USB phone charger. I discovered that the violet wire is hot with the key in the "R" position. I need to turn the key all the way to "OFF" to de-energize that wire, which also means locking the handlebars all the way left or right. Mine's an '03 and yours is a '97 so they might be different, but it's probably something you'll want to check. Afternoon RogerC60 It's the same on the 1100RT as the key has to go all the way to the OFF position to power-down that violet radio wire. The violet wire also stays on (hot) during engine cranking as it doesn't go through the load-relief relay. Link to comment
Paul De Posted November 14, 2020 Share Posted November 14, 2020 Hi Dave, Looks like you found the info on what that harness was intended to be used for by BMW, and what sort of powered farkle owners have used the switched violet wire for in place of a radio. I used my violet switched power lead for a nicely made in a basement set of turn+running light turn signals. Very old school using dual filament 1157 bulbs. Really does help with the front visibility thing on the R1100RT. I did this farkle before I bought a Kissan Signal minder which is a better way to go if you were ever to want this feature and turn signal cancelling because it is a program feature in the Signal minder unit. Link to comment
Artie John Posted November 14, 2020 Share Posted November 14, 2020 Thanks for the info. Used the purple wire to connect the power hub trigger, now on to the high/low beam triggers for the lights themselves. Link to comment
Dave P Posted November 15, 2020 Author Share Posted November 15, 2020 Paul and others- My plan is to install an on board garage door opener, wired to power. My old XC70 Volvo has a opener incorporated into the sun visor. You can link it to open 3 different doors. I purchased a visor for 5$ at the junkyard, ripped it apart to extract the opener ( it's about the size of a deck of cards). Two wires. I was going to wire it to the hot red and brown ground lines and mount it right under the speedo (speedo on the left?) opens door when button pushed. I think it's pretty cool. Hopefully it will actually work. Dave Link to comment
Dave P Posted November 16, 2020 Author Share Posted November 16, 2020 Looks like this, called "Homelink" Link to comment
dirtrider Posted November 16, 2020 Share Posted November 16, 2020 32 minutes ago, Dave P said: Looks like this, called "Homelink" Morning Dave That thing doesn't look to be waterproof, is rain water or washing the motorcycle going to mess it up? I just carry a small universal remote in my riding gear pocket (about the size of a book of matches & about twice as thick). I can usually push the buttons on it without even removing it from my pocket. The best part is that it works with any motorcycle that I might be riding that day. Link to comment
bmwnomad Posted November 16, 2020 Share Posted November 16, 2020 Just as another option... I've been looking at this transmitter and it looks promising Gentex GENHLBP1 Wireless Homelink Garage Door Opener Waterproof, self contained battery (don't know the life, 10 years?, replaceable?) Mounts into a 2"x1" hole, 3" depth. Link to comment
Hosstage Posted November 16, 2020 Share Posted November 16, 2020 Harley offers a garage door opener triggered by the high beam headlight switch, not sure if it is a universal unit and would work with other models (I assume it would, or that there are models that will.) I'm old school. I still just get off the bike and open the door. This allows the bike to cool a bit, and dissipate some of the extra fuel and oil smell that tends to build up on my old HD before I roll it in. I know you Beemer guys don't have that issue! Link to comment
Paul De Posted November 16, 2020 Share Posted November 16, 2020 Haha Dave P. When I saw the visor pic, my initial thought was, Wait-what? why/where in the hell is he going to mount a car sun visor. On the helmet like a vinyl mohawk fin? Link to comment
Dave P Posted November 17, 2020 Author Share Posted November 17, 2020 It will all be sealed up from moisture. Link to comment
Paul De Posted November 17, 2020 Share Posted November 17, 2020 How are you going to do that? Seal it in a blob of silicone seal, or crystal clear acrylic seal? I guess an obvious place to keep if dry is inside one of the two little cubby boxes just below the speakers. The right side already has access and I suppose a seal for the USB port. but that side is already cramped for space. Link to comment
AndyS Posted November 17, 2020 Share Posted November 17, 2020 Hi Paul, just to remind you that there is only one cubby (lefthand side) on the Oilhead. Link to comment
Paul De Posted November 17, 2020 Share Posted November 17, 2020 oops, got my vintages goofed up. My bad. The trusty old boy is already put up for the winter and I have been only riding my Waterhead of late. Link to comment
waynerd Posted November 19, 2020 Share Posted November 19, 2020 This has been shared before, but in my estimation, worthy of repeat. One of the best videos on the subject of garage door opener remotes for motorcycles. For some reason, it doesn't work at my house: Link to comment
