MontanaMark Posted October 28, 2020 Share Posted October 28, 2020 Hi, I am going to mount some aux lights on my 2011 g650gs and bought a fuzeblock to handle the wiring. The fuzeblock offers both always-on and switched fuses. To use the switched option, I have to tap a wire that is only powered when the key is on. I was thinking of using the tail light wire as a tap to signal the fuzeblock that the key is on/off. Don't want them to remain on when I shut the bike off. Does anyone have a better suggestion? I'm sure someone has done this before, so I really don't want to reinvent the wheel... Thanks, Mark Link to comment
dirtrider Posted October 28, 2020 Share Posted October 28, 2020 6 hours ago, MontanaMark said: Hi, I am going to mount some aux lights on my 2011 g650gs and bought a fuzeblock to handle the wiring. The fuzeblock offers both always-on and switched fuses. To use the switched option, I have to tap a wire that is only powered when the key is on. I was thinking of using the tail light wire as a tap to signal the fuzeblock that the key is on/off. Don't want them to remain on when I shut the bike off. Does anyone have a better suggestion? I'm sure someone has done this before, so I really don't want to reinvent the wheel... Thanks, Mark Morning Mark There are so many versions on those g650gs that finding your exact wiring diagram is is difficult. I have some but not all the F/G wiring diagrams. I usually use the green/violet wire going to the diagnostic plug as a key-on 12v tap but that assumes your specific 650 has that (worth a look as that green/violet key-on 12v circuit is fuse protected) Link to comment
MontanaMark Posted October 28, 2020 Author Share Posted October 28, 2020 Dirtrider, Thanks for the info. I will look for that wire when I get the panels off and get in there. If I remember, I'll take pictures of the process and post as a how-to. Regards, Mark Link to comment
