oilhead1100s1150rt Posted October 8, 2020 Share Posted October 8, 2020 Good Day, Please take a listen to the attached videos (listen). I have done work in the gas tank...fuel filter replacement, fuel lines, new quick connects. I may have not gotten all the old fuel out at the time of the work. If there was any left in the tank, it sat for over a year. After putting everything back together, the right side plug fouled (rich). I have replaced both plugs and added a small amount of fresher gas. There is improvement, but still not running the best. Video #1 = a loud thump is heard Video #2 ( second post - due to size) = I hear a chirp...sounds like the injector making the noise? Appreciate any feedback. Dave IMG_1579.MOV Link to comment
dirtrider Posted October 8, 2020 Share Posted October 8, 2020 11 minutes ago, oilhead1100s1150rt said: Good Day, Please take a listen to the attached videos (listen). I have done work in the gas tank...fuel filter replacement, fuel lines, new quick connects. I may have not gotten all the old fuel out at the time of the work. If there was any left in the tank, it sat for over a year. After putting everything back together, the right side plug fouled (rich). I have replaced both plugs and added a small amount of fresher gas. There is improvement, but still not running the best. Video #1 = a loud thump is heard Video #2 ( second post - due to size) = I hear a chirp...sounds like the injector making the noise? Appreciate any feedback. Dave IMG_1579.MOV 9.17 MB · 0 downloads Afternoon Dave Yes, it doesn't sound great but the video is limited & too short to tell you much over the internet. What does it sound like when you revv it a little? Does it have good power when you try to ride it? After about 10 seconds after a cold start shut it off & see if both front exhaust pipes are about the same temperature???????? Link to comment
szurszewski Posted October 8, 2020 Share Posted October 8, 2020 I’m no help, but I did notice in this video, at the same time as the thump, a large amount of dust is knocked loose from the intake tube - almost like the butterfly valve or something like that, was slapping shut/open suddenly. Link to comment
oilhead1100s1150rt Posted October 8, 2020 Author Share Posted October 8, 2020 rightsidechirp.m4a Not sure this helps any. This is a voice memo file. If you are on an apple, just drag to your desk top and listen, or download. 21 minutes ago, dirtrider said: Afternoon Dave Yes, it doesn't sound great but the video is limited & too short to tell you much over the internet. What does it sound like when you revv it a little? If you can open the m4a file, it is in there. If not, I believe it sounds rather healthy. Some breaking up when constant rpm. Does it have good power when you try to ride it? I have not put everything back on for a road test just yet. Will do so latter on. After about 10 seconds after a cold start shut it off & see if both front exhaust pipes are about the same temperature???????? Yes, both pipes read approx 140 - 160F after the start up. Link to comment
dirtrider Posted October 8, 2020 Share Posted October 8, 2020 5 minutes ago, oilhead1100s1150rt said: rightsidechirp.m4a 340.29 kB · 2 downloads Not sure this helps any. This is a voice memo file. If you are on an apple, just drag to your desk top and listen, or download. Afternoon Dave That helps a little, you have a definite misfire on one side (probably the right side). Problem is the audio gives us no clue on what is causing it. Sounds sort of like it is firing on a partially open intake valve, but again, nothing pointing us to the why or what that is causing it. Might just be a fuel injector that isn't squirting correctly, or a spark problem, of even a valve that isn't sealing correctly. Lots you can do by digging (much) deeper, is that something that you want to tackle? Link to comment
West_Coaster Posted October 8, 2020 Share Posted October 8, 2020 Could one of the throttle cables be pulled causing an out of sync issue? Link to comment
oilhead1100s1150rt Posted October 8, 2020 Author Share Posted October 8, 2020 I got away with an easy fix. I missed it the first time through. The fast idle "bmw choke" cable was tighter then it should have been. I adjusted it accordingly and she is running just fine. I never heard such a noise before, still not sure what it was, but gone now. Thanks for the quick responses !! Dave Link to comment
