MagYukon Posted September 28, 2020 Share Posted September 28, 2020 Hello, I have now been riding my bike for about 3000 km. When there is a lot of wind, especially sideways, I have a funny feeling about the stability of the bike. Pretty hard to describe but it is as if the wheels want to move from left to right. Just like if my tires was on ice and slippering from left to right. It is true that I do not have a lot of motorcycle experience yet, but I wonder if this is normal or not. Before that bike, the only other one I rode was a Honda CB500 during my training. Even in hard lateral wind with this bike, I had the feeling to be pushed sideways, but never like what I feel on the RT. My friends all have Harleys and on the same rides they didn't seem as affected by the wind as I did. Could it be a problem with the bike or if I'm the one worrying too much? here are some details: new front and rear tires (Michelin Pilot Road 5) I tried having them at recommended pressure (26F / 32R) and I also tried as some here says (34F / 42R) without any change in that feeling the bike at 34,000 km My next step is to have one of my friend tried it and get their feeling about it thanks for your thoughts ! Link to comment
Skywagon Posted September 28, 2020 Share Posted September 28, 2020 MagYukon....a couple of things. Anything will move with the wind. Bike, motorbike, car, boat, etc. However let me make a couple of suggestions to you. Your tire pressure should be something higher. My recommendation to you is 36-38 on front and 42-44 on the rear. Those numbers you quoted, especially the front are way too low. I personally run 38/42 Second the RT has a big fairing and big windshield. Those contribute to wind shift. There isn't anything to do with the fairing, but you can adjust your windshield to the lowest point you are comfortable. If your windshield is all the way up it will contribute to wind drift. Harleys drift too, especially the ones with the bat wing fairing. I've ridden plenty and that fairing at speed moves the bike. If the Harley is the larger bikes like the Ultra Classic, they weigh at least 300lbs more than your bike. This will add some stability as well as the lower center of gravity...but they move too. Others will offer some advice like changing riding positions, hold the handlebars loosely, etc...but correct tire pressure and windshield placement will help you a lot. 1 Link to comment
wbw6cos Posted September 28, 2020 Share Posted September 28, 2020 It could be both you and the bike. The RT moves a bit in strong cross winds, but your experience tells you that it was not good; it is all the way you perceive how it affects your ride. After some more riding on your bike to get to know it, you will find out that it is not all that bad and overtime, your mind will adjust accordingly. You will still feel uneasy, but will tolerate it more. .....and the tire pressures should be at recommended pressure. Thanks for asking and ride safe! 1 Link to comment
dirtrider Posted September 28, 2020 Share Posted September 28, 2020 43 minutes ago, wbw6cos said: It could be both you and the bike. The RT moves a bit in strong cross winds, but your experience tells you that it was not good; it is all the way you perceive how it affects your ride. After some more riding on your bike to get to know it, you will find out that it is not all that bad and overtime, your mind will adjust accordingly. You will still feel uneasy, but will tolerate it more. .....and the tire pressures should be at recommended pressure. Thanks for asking and ride safe! Afternoon MagYukon There is always the possibility that there is something going on with your motorcycle or tires so keep that in mind. We can't ride or feel you motorcycle in the wind over the internet so about all we can address is what we think you are feeling. All in all the BMW 1200RT's are pretty stable in the wind but as Skywagon said they all move in the wind to a certain extent. It usually boils down to how you (the rider) reacts & how you perceive the movement. You didn't say how fast you were riding or on what kind of roads, that can make a big difference in what you you feel & how to react to a small movement. If you tense up when the motorcycle starts moving a little that can turn a slight wind movement into big deal in your mind. In windy conditions you need to loosen up, ride with bent elbows, & allow the motorcycle to move a little under you. If you stiffen up, go to straight arms & over-react to a little lateral movement, or wiggle, then it will feel like you are fighting the wind with no chance of precisely controlling it. If the wind starts moving you, don't over-react, let it move around a little, then lightly (very lightly) put a little bar in it to bring it back on line. (don't fight it, just gently work with it) Personally, I really like riding fast in a good brisk fluctuating side wind, makes the bike dance, so I just go light on the controls & intuitively lead the dance. 5 Link to comment
MagYukon Posted September 28, 2020 Author Share Posted September 28, 2020 1 hour ago, dirtrider said: Personally, I really like riding fast in a good brisk fluctuating side wind, makes the bike dance, so I just go light on the controls & intuitively lead the dance. Maybe that just sums up my feeling. the bike dancing under me (or with me). I'll take all your advice and try to have fun instead of trying to counter act it ! Thanks for your inputs ! Link to comment
MagYukon Posted September 28, 2020 Author Share Posted September 28, 2020 I also just realize that the previous owner translated the pressure fomr Bar to PSI and wrote them on the owner manual. But he did it wrong. I don't know how he came to that, but he wrote 26F/32R which are far from reality... again, thanks ! 1 Link to comment
Pappy35 Posted September 29, 2020 Share Posted September 29, 2020 Yeah. 26 up front is dangerously low. I'm surprised the TPS triangle didn't light up yellow (or even red). Given that, you should carefully examine the tread on your tires. If the center is worn flat, so instead of a smooth curve-like profile it's flat in the center and round on the edges, that could be a big part of your problem. A severely center-flat worn tire will behave in all kinds of strange ways. If you're not sure, take pictures of your front and rear tires such that we can see the profile (like looking straight down at the ground from above the front and something similar from the rear) and we can help you. Also, believe anything Dirtrider tells you. He is THE technical guru on here. Link to comment
dduelin Posted September 29, 2020 Share Posted September 29, 2020 Speaking in generalities I think most of us agree that the RT series are very stable motorcycles with no dangerous qualities as long as the machine is in correct working order so we are naturally first going to explore areas like tire condition, tire pressures, or suspension adjustments in response to the OP's question. One of the traits of RT's is that despite their weight and full fairings they remain light on their feet and very nimble. To a rider without much comparative experience the RT may move around a lot in wind but it's also more fun to ride on winding roads and that is a trade off most gladly make. 3 Link to comment
6speedTi Posted September 29, 2020 Share Posted September 29, 2020 15 hours ago, MagYukon said: I also just realize that the previous owner translated the pressure fomr Bar to PSI and wrote them on the owner manual. But he did it wrong. I don't know how he came to that, but he wrote 26F/32R which are far from reality... again, thanks ! I found this article about tire wear helpful. http://www.rattlebars.com/tirewear/ Link to comment
MagYukon Posted September 29, 2020 Author Share Posted September 29, 2020 10 hours ago, Pappy35 said: Yeah. 26 up front is dangerously low. I'm surprised the TPS triangle didn't light up yellow (or even red). I don't have the TPMS option ! That's why there's no light Link to comment
dduelin Posted September 29, 2020 Share Posted September 29, 2020 That's easy to fix. 1 Link to comment
MontanaMark Posted September 29, 2020 Share Posted September 29, 2020 MagYukon, If you have ESA, make sure you don't have it set in 'Comfort' mode. I've noticed that this mode tends to make the suspension a little 'squishy' in the corners. I believe the same 'squishiness' would be felt in a strong crosswind. By the way, 'squishy' is a technical term... Cheers, Mark Link to comment
GordonB Posted September 29, 2020 Share Posted September 29, 2020 One thing to add is if your are using the 49L top box. I have found the top box adds quite a bit of movement in cross winds, more so with sudden gusts. Link to comment
Hosstage Posted September 29, 2020 Share Posted September 29, 2020 All good points. When it does move around, remember to keep eyes up and forward, loosen your core grip, and let the bike move, just go with it. Have you ridden on a long grate bridge? That will really test your idea of what a wandering bike really is! 1 Link to comment
MagYukon Posted September 29, 2020 Author Share Posted September 29, 2020 18 minutes ago, Hosstage said: All good points. When it does move around, remember to keep eyes up and forward, loosen your core grip, and let the bike move, just go with it. Have you ridden on a long grate bridge? That will really test your idea of what a wandering bike really is! Yes I have. Fortunatly, it was not windy that day Suprisingly, it was not as bad as i thought it would be. Link to comment
MagYukon Posted September 29, 2020 Author Share Posted September 29, 2020 1 hour ago, dduelin said: That's easy to fix. can you linked me to what it is eaxctly ? is this the kind of things you have to add to the valve stems ? Link to comment
dirtrider Posted September 29, 2020 Share Posted September 29, 2020 1 hour ago, MagYukon said: Yes I have. Fortunatly, it was not windy that day Suprisingly, it was not as bad as i thought it would be. Afternoon MagYukon If riding loose & relaxed then usually not too bad with regular street tires (especially at the low end of tire pressure specs). They will usually walk around a little but not off line enough to make meaningful course corrections. Now that can't be said when using knobby tires as that is like catching an edge with every other new knob entry into the grating. I ride a lot of high speed loose gravel & I will take the high speed loose gravel any day over deep knobby tires on bridge grating. (I have a friend in the U.P. of Michigan & visiting him usually involves at least a couple or more miles of bridge grating in the summer months, usually with buffeting winds to add excitement & entertainment). Link to comment
MuddBuddha Posted September 29, 2020 Share Posted September 29, 2020 I have a 2008 RT and a 2014 Victory Vision Tour that is like sitting atop a billboard in strong crosswinds. Relaxing on the grips is always best and allow the bike to track forward, but lane positioning is fairly important, particulary on a two lane road so you leave yourself room to counter steer against the wind to keep from crossing yellows; or going off the road completely. If you look on Amazon for motorcycle TPMS, you'll find a lot of options. Here's one I settled on due to performance and working longevity...and you can see from my purchase history, I've put them on almost every bike I've had. Link to comment
Pappy35 Posted September 29, 2020 Share Posted September 29, 2020 8 hours ago, MagYukon said: I don't have the TPMS option ! That's why there's no light Yup. That explains it all right. That gadget Mudd linked to is pretty dope. Not too expensive either. Get one. Knowing tire perssure saved my ass one day. It's one of those "I'll never have a car (or bike) without that again" things. 1 Link to comment
dduelin Posted September 29, 2020 Share Posted September 29, 2020 6 hours ago, MagYukon said: can you linked me to what it is eaxctly ? is this the kind of things you have to add to the valve stems ? This is the TPMS pictured and yes the sensors mount on the valve stems. You do not want to mount the sensor on a rubber valve stem so I installed an aluminum 83 degree valve in the rear wheel. The picture is of the same 83 degree stem in my Goldwing rear wheel. In the short run you can fabricate a plastic tube stand-off that prevents a rubber stem from bending at speed. The front of course is no problem with the BMW wheel. https://www.amazon.com/gp/product/B07BFH9WZ7/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 Link to comment
lather Posted September 29, 2020 Share Posted September 29, 2020 The only thing I can add to this thread is the effect of speed. Generally the faster you are going the more stable the bike is. I've know a few riding friends that did not know this and made the mistake of slowing down in high side wind conditions. The faster the front wheel turns the more resistant it is to changing direction whether the input is yours or the winds. 1 Link to comment
6speedTi Posted September 30, 2020 Share Posted September 30, 2020 9 hours ago, MontanaMark said: MagYukon, If you have ESA, make sure you don't have it set in 'Comfort' mode. I've noticed that this mode tends to make the suspension a little 'squishy' in the corners. I believe the same 'squishiness' would be felt in a strong crosswind. By the way, 'squishy' is a technical term... Cheers, Mark So what does Squishy Squashy mean in technical terms? 🤣 Link to comment
MontanaMark Posted September 30, 2020 Share Posted September 30, 2020 13 hours ago, 6speedTi said: So what does Squishy Squashy mean in technical terms? 🤣 For me, it means that the suspension feels too soft in the corners. Both the front and rear tires seem to wander, not holding the line I've chosen. Mind you, this happens only in sharp twisties, at spirited speeds. Not in evidence so much in sweepers. Solution: use 'normal' or 'sport' setting! My fellow riders without ESA get tired of me commenting over the Sena how much I love my bike, especially the suspension. 'Have I mentioned how comfortable this bike is?" "Shut up, Mark" Cheers, Mark Link to comment
MagYukon Posted September 30, 2020 Author Share Posted September 30, 2020 Thanks to all of you for your inputs and comments. Just need more time to get used to it I guess. If only there's more time in front of me to ride it before snow Link to comment
Ponch Posted October 2, 2020 Share Posted October 2, 2020 I had a 1600 Nomad before my RT and the Nomad was more stable in cross winds. It was the only thing it was better at. It was 250lbs heavier. Link to comment
lkraus Posted October 2, 2020 Share Posted October 2, 2020 I don't usually have a crosswind stability issue unless I'm around a semi, which can cause a lot of buffeting. The area of buffeting seems to depend on wind direction and speed, so sometimes I'm alongside before feeling it, sometimes I'm several hundred feet back. Best solution is to maintain a relaxed grip and stay well back, or pass the truck if possible. Link to comment
MagYukon Posted October 5, 2020 Author Share Posted October 5, 2020 Good morning, I rode my RT this weekend after putting it at 36/42 PSI. I also took your advise to relax and to enjoy the ride. it was not strongly windy but i felt my ride more comfortable than before. Thanks for all your inputs ! Link to comment
MagYukon Posted August 23, 2021 Author Share Posted August 23, 2021 Just a quick update on my bike. After 18,000Km I guess I'm more used to my bike and how to handle it. So everything is better than before. When I bought my RT last year, the previous owner put on new Michelin Road 5 GT tires. Last week I changed them to Pirelli Angel GT 2. The only thing I can say is that I haven't really been able to enjoy the bike for a year. Even on a straight line, when I came to a crack in the asphalt, the bike was moving from left to right. Same thing in strong wind. Now it's ljust going straight forward. As i was my first bike ever, I had nothing to compare. Now I understand why everyone says the RT is a fantastic, stable and fun motorcycle. I can now enter a curve without being afraid. With the Michelin tires, even when they were brand new, I never had the feeling I have today. It is almost as if the motorcycle is on a rail. The guy at the shop told me he would never have installed Road 5 GT on an RT. According to him, the structure of the tire is not rigid enough and the tire deforms under the weight of an RT. I cannot say whether he is right or not, but one thing i'm sure, what he sold me is night and day. Link to comment
dduelin Posted August 23, 2021 Share Posted August 23, 2021 1 hour ago, MagYukon said: Just a quick update on my bike. After 18,000Km I guess I'm more used to my bike and how to handle it. So everything is better than before. When I bought my RT last year, the previous owner put on new Michelin Road 5 GT tires. Last week I changed them to Pirelli Angel GT 2. The only thing I can say is that I haven't really been able to enjoy the bike for a year. Even on a straight line, when I came to a crack in the asphalt, the bike was moving from left to right. Same thing in strong wind. Now it's ljust going straight forward. As i was my first bike ever, I had nothing to compare. Now I understand why everyone says the RT is a fantastic, stable and fun motorcycle. I can now enter a curve without being afraid. With the Michelin tires, even when they were brand new, I never had the feeling I have today. It is almost as if the motorcycle is on a rail. The guy at the shop told me he would never have installed Road 5 GT on an RT. According to him, the structure of the tire is not rigid enough and the tire deforms under the weight of an RT. I cannot say whether he is right or not, but one thing i'm sure, what he sold me is night and day. I'll give that tire feel can be highly subjective and different tires can feel much different between tire brand and models on the same bike but you must have heard or understood something different from what he actually said or meant to convey The Road 5 GT is recommended by Michelin for the RT. It has the speed and load rating required by BMW for your bike and most certainly does not deform under the weight of the RT. I can only compare it to Bridgestone T31s on my 2007 but the Road 5 is my favorite sport touring tire after two sets on my bike. Wet or dry it's supremely sure footed and delivers confidence in spades. 2 Link to comment
bruce2000ltc Posted August 23, 2021 Share Posted August 23, 2021 Dave, what topcase is that on your bike? -Thanks Link to comment
9Mary7 Posted August 23, 2021 Share Posted August 23, 2021 2 hours ago, MagYukon said: The guy at the shop told me he would never have installed Road 5 GT on an RT. According to him, the structure of the tire is not rigid enough and the tire deforms under the weight of an RT You have a knowledgeable tire guy. Your bike came from BMW with Metzeler tires (which is Pirelli as well) for good reason. Enjoy!! Link to comment
9Mary7 Posted August 24, 2021 Share Posted August 24, 2021 5 hours ago, dduelin said: The Road 5 GT is recommended by Michelin for the RT I'm sure they(Michelin) have a Michelin they recommend for every application.... doesn't mean the bike's manufacturer finds it suitable, but I'm glad you like them. I knew from my own experience what his issue was when he mentioned the Michelins. Link to comment
MagYukon Posted August 24, 2021 Author Share Posted August 24, 2021 15 hours ago, dduelin said: I'll give that tire feel can be highly subjective and different tires can feel much different between tire brand and models on the same bike but you must have heard or understood something different from what he actually said or meant to convey The Road 5 GT is recommended by Michelin for the RT. It has the speed and load rating required by BMW for your bike and most certainly does not deform under the weight of the RT. I can only compare it to Bridgestone T31s on my 2007 but the Road 5 is my favorite sport touring tire after two sets on my bike. Wet or dry it's supremely sure footed and delivers confidence in spades. Hi Dave, I know that those Raod 5 are sold by Michelin to go on the RT. That's why I never suspected that my bad feeling was due to the tires. But I can assure you that I'll never get back to Road 5 on my RT after trying the Pirelli Angel GT 2. It's probably a question of preference, riding style and possibly quality of the roads were we ride. I only wnated to share my personnal very short experience. If it can helps someone ! For me, if I had came to a post like that last year, I would probably have tried to replace my tires very sooner that I did. Link to comment
dduelin Posted August 24, 2021 Share Posted August 24, 2021 23 hours ago, bruce2000ltc said: Dave, what topcase is that on your bike? -Thanks Coocase which if I understand correctly was a house brand offered by Twisted Throttle. I believe the line is discontinued now. Link to comment
dduelin Posted August 24, 2021 Share Posted August 24, 2021 8 hours ago, MagYukon said: Hi Dave, I know that those Raod 5 are sold by Michelin to go on the RT. That's why I never suspected that my bad feeling was due to the tires. But I can assure you that I'll never get back to Road 5 on my RT after trying the Pirelli Angel GT 2. It's probably a question of preference, riding style and possibly quality of the roads were we ride. I only wnated to share my personnal very short experience. If it can helps someone ! For me, if I had came to a post like that last year, I would probably have tried to replace my tires very sooner that I did. I'm glad you found the answer for you and the bike is fun to ride again. That is the important thing. In this thread you mention the tires being Road 5 and Road 5 GT at different times. As you know they are two different model of tire and Michelin does not recommend the R5 non GT on the RT. What tires did you have on the bike? Link to comment
MagYukon Posted August 25, 2021 Author Share Posted August 25, 2021 13 hours ago, dduelin said: I'm glad you found the answer for you and the bike is fun to ride again. That is the important thing. In this thread you mention the tires being Road 5 and Road 5 GT at different times. As you know they are two different model of tire and Michelin does not recommend the R5 non GT on the RT. What tires did you have on the bike? Michelin Road 5 GT is what was on the bike. Sorry for the confusion. Link to comment
