KDeline Posted September 27, 2020 Share Posted September 27, 2020 Does anyone know if the belt size changed from 2007 to 2009? I have a used belt from a 2007 GSA with a number 12.31-7890 571-692637. From a 2009RTP is is 11.31-8528 385-163667. Seems like different size but close. From the RTP I have a constant bird chirp mixing with a loud intermittent scraping sound coming from the front of the engine. I thought it has to do with the belt. Alternator turns freely. 06 11 31 8 528 385 RIBBED V-BELT - 4PK582 Above is PN for RT and the GSA. I am wondering if the wrong belt was installed and on which bike? Link to comment
dirtrider Posted September 27, 2020 Share Posted September 27, 2020 53 minutes ago, KDeline said: Does anyone know if the belt size changed from 2007 to 2009? I have a used belt from a 2007 GSA with a number 12.31-7890 571-692637. From a 2009RTP is is 11.31-8528 385-163667. Seems like different size but close. From the RTP I have a constant bird chirp mixing with a loud intermittent scraping sound coming from the front of the engine. I thought it has to do with the belt. Alternator turns freely. 06 11 31 8 528 385 RIBBED V-BELT - 4PK582 Above is PN for RT and the GSA. I am wondering if the wrong belt was installed and on which bike? Afternoon KDeline Your 2009 1200RT should take the 11.31-8528 385-163667 that is a 4PK 582 (belt length of 582mm) The 12.31-7890 571-692637 is a 4PK 592 (belt length of 592mm). If you suspect that your noise is coming form the belt then just remove the belt & run the engine to see is the noise goes away. (all the belt does is run the alternator so it will run fine without the belt for a while) Link to comment
KDeline Posted September 27, 2020 Author Share Posted September 27, 2020 I knew I could count on you DR. I replaced that GSA belt years ago as a precaution off of bike I bought new, seems like the wrong belt was installed from the factory. Not encouraging. So for now I put on the old 12.31 belt, the chirping is gone, need to ride a bit to see if the loud whatever sound is gone. Will order new belt. Thank you once again. 1 Link to comment
KDeline Posted September 27, 2020 Author Share Posted September 27, 2020 I just noticed both the 11.31 and 12.31 are 4PK 582. Same size? Link to comment
dirtrider Posted September 27, 2020 Share Posted September 27, 2020 1 hour ago, KDeline said: I just noticed both the 11.31 and 12.31 are 4PK 582. Same size? Afternoon KDeline Actually I don't think they are the same size (if you have an early belt), BMW had slipping issues with the early 12.31-7890 571-692637 so supposedly there was a belt length change on the later ones with no change in part number (I haven't ever personally measured them but some of early belts did slip, especially when wet). Link to comment
9Mary7 Posted December 28, 2020 Share Posted December 28, 2020 On 9/27/2020 at 11:43 AM, dirtrider said: some of early belts did slip, especially when wet Some of our authority bikes actually shredded those early stretch belts.... They did squeal when ridden hard. Link to comment
