taylor1 Posted September 22, 2020 Share Posted September 22, 2020 Anyone run across any great battery deals ? Looking for my 1150rt TIA Link to comment
Foot Posted September 23, 2020 Share Posted September 23, 2020 I have always had good luck with Battery Mart I get much longer life out of these than the OEM BMW battery. Alan Link to comment
9Mary7 Posted September 24, 2020 Share Posted September 24, 2020 I still use the USA made Yuasa battery. Last long and reliable. Link to comment
realshelby Posted September 24, 2020 Share Posted September 24, 2020 Just save up and buy the Odessey PC 680. May be the last one you need to buy. Clearly proven superior to any other battery for power and long life. 1 Link to comment
taylor1 Posted September 24, 2020 Author Share Posted September 24, 2020 I have an Odyssey PC 680 in my 60/6 for 9 years now . Never on a tender , I up graded my diode board and V.R so it keeps it topped off quite well. Used it yesterday ,and it cranked the bike like new. They are excellent batteries. Having said that , I have a signal minder on the RT which has a parasitic drain. I don't have or want to buy at this time the correct trickle charger for the Odyssey. Gonna stick with either an AGM or gel . My current charger should keep them topped off. Guess I should have mentioned in my post. One of these days I'll do the mod. to the Minder Thanks for the replies Link to comment
dirtrider Posted September 24, 2020 Share Posted September 24, 2020 58 minutes ago, taylor1 said: I have an Odyssey PC 680 in my 60/6 for 9 years now . Never on a tender , I up graded my diode board and V.R so it keeps it topped off quite well. Used it yesterday ,and it cranked the bike like new. They are excellent batteries. Having said that , I have a signal minder on the RT which has a parasitic drain. I don't have or want to buy at this time the correct trickle charger for the Odyssey. Gonna stick with either an AGM or gel . My current charger should keep them topped off. Guess I should have mentioned in my post. One of these days I'll do the mod. to the Minder Thanks for the replies Morning taylor1 AGM is a pretty solid battery design, you really don't want a GEL if you can at all avoid it. GEL batteries have 2 things going for them, (1) is- they can be mounted & used upside down, (2) they are leakproof enough (even upside down) to allow manufactures to ship a motorcycle with the battery pre-installed. The downside to most motorcycle GEL batteries is they usually die a sudden death (start just fine then very next start totally dead). Also, they do not handle overcharging very good as once the GEL bubbles away from a plate in a spot then that spot on the plate never recovers. Link to comment
