airfin Posted May 8, 2006 Share Posted May 8, 2006 i am running an autocom pro-7 system. I just got part #152 which allows you to wire it direct to the bike. I ran the power lead to the tail light wire as suggested in the install sheets. I ran the negative to the bolt/washer assembly for the under seat helmet hooks. As soon as i start up the bike, i have get a ton of noise coming through from the alternator, as it changes with the RPMS. Anyone had this problem? What did you do to resolve it? any help would be great. This is one a 98 rt100. thanks in advance Link to comment
EffBee Posted May 8, 2006 Share Posted May 8, 2006 There is only one place for the negative wire to go and that's straight to the battery. Nowhere else. Try this and see what it does for the noise. Let us know. Link to comment
airfin Posted May 10, 2006 Author Share Posted May 10, 2006 simple enough! got it up and going tonight. thanks for the info! Link to comment
