Dennis Andress Posted May 5, 2006 Share Posted May 5, 2006 In this thread Someone recommended NGK DCPR7E spark plugs for the K12. Here are my observations after using a set for 3,000 or 4,0000 miles (sorry, I don't keep track of mileage very well.) The bike runs smoother with these plugs especially at higher revs. In fact, I now find myself normally running at 5,000 to 6,000 rpm which the K likes but I didn't do with the OEM plugs. The bike does backfire less on de-acceleration. Idle is smoother. On the down side, My #4 plug wire failed and wouldn’t stay tight on the spark plug. The NGK plug immediately began misfiring. I put the OEM plugs back in and the misfire cleared enough to make the bike rideable until the new wire arrived. I contribute this to the NGK plugs .032. I find these plugs a big improvement over the Bosch plugs. You can get them at NAPA. Dennis Link to comment
Bruce C Posted May 6, 2006 Share Posted May 6, 2006 I second your opinion of the NGK plugs. I installed NGK's(DCPR7E) at the 600 (yes, six hundred) mile service. The KRS now has 18,100 mi. I change out the plugs every 6,000mi. (for no reason other than the plugs are to be inspected every 6,000mi.(per manual) and the plastic is a pain to remove). The NGK's are just as good in a K as they are in any other application. My fuel mileage is consistantly 46-48 mpg. I purchased the plugs from my neighborhood M/C shop for $3.55ea. Bruce C Link to comment
Dennis Andress Posted May 6, 2006 Author Share Posted May 6, 2006 My fuel mileage is consistantly 46-48 mpg. How do you do that? 32 mpg is my norm. Link to comment
JerryMather Posted May 6, 2006 Share Posted May 6, 2006 32 mpg is my norm. I can't imagine why you only get 32 MPG. Link to comment
Dennis Andress Posted May 6, 2006 Author Share Posted May 6, 2006 I can't imagine why you only get 32 MPG. Damn Loud Handle..... Link to comment
Bruce C Posted May 6, 2006 Share Posted May 6, 2006 Dennis On a KRS you are not generally lugging around the side cases(wind resistance) all the time, the shorter windscreen(a big item, I can see a difference when I put the GT shield on this winter) makes a big difference. The KRS is about 35lbs. lighter than the GT. No power windscreen motor to lug around. I do have ABS,cruise control and all the junk except a heated seat. The only time my mileage dips below 40mpg. is on I-10 to Phoenix at 4:00am. After that run It's back up to 46mpg. Fuel light comes on around the 175-180mi. mark and I have run it to 206mi.(nervous time) between stops. Aside from that I don't know why all the RS's get noticably better fuel mileage than a GT. Another thing is that we live within 40mi. of each other. So, we ride the same roads. To give you an example: On Thursday the 4th. I rode from Hemet to Julian via. Mesa Grande, Santa Ysabel,back around Lk. Henshaw, over Mt. Palomar down to the Pala casino, back road to Temecula. Then I-15-I-215 and Rt# 74 home. Traveled 177mi. consumed 3.675gal. for 48.21avg.mpg. Bruce C Link to comment
Dennis Andress Posted May 6, 2006 Author Share Posted May 6, 2006 May I ask what your average speed is out there? I'll admit that when I travel the roads around Julian I'm moving well over 80 mph. Local freeway travel is normally done at 90-100 mph. (That's just a little bit faster than traffic....) Dennis Link to comment
Bruce C Posted May 6, 2006 Share Posted May 6, 2006 Try dropping it back a peg or two. Then maybe you wouldn't be wondering how I average 46-48mpg. Also I would like to see you running well over 80mph aroung Julian. Actually I should say. "What for"? Bruce C Link to comment
ELP_JC Posted May 8, 2006 Share Posted May 8, 2006 Dennis, do you need aftermarket wires to properly fit the NGKs? The gap is fine, as 0.8mm is recommended by the factory, and 0.032 is just a hair above that (0.8128mm, to be precise). I just bought new Boschs for my 12K service, but I like having a smoother idle and high-rpm operation. But don't want the wires to come loose. Although mileage has a lot to do with speed, it also has a lot to do with altitude. I just got my best mileage ever on a recent AZ trip (78, 191, and NM 152, etc); a whopping 54 mpg. And I was hauling butt at 90 mph on the flat stuff, and on the twisties as well (no chicken strips). I was taking care of my tires, but after noticing they wouldn't hit the wear bars on this trip EITHER (went to a Big Bend trip 2 weeks earlier), I sped up to my usual triple digits on the way back, and that logically brought my mileage down into the high 40s; still not bad at all. I live at 4K' of altitude, by the way. And the tires are Conti Road Attacks; awesome tires. Got 5,700 on them (a record for me), and they still have 500 miles left before the wear bars, but will ditch them due to an upcoming week-long trip to CO. Will try Pirelli Stradas sitting in the garage (free front tire from Pirelli; couldn't resist), but most likely will be going back to Contis. Good day. Link to comment
Dennis Andress Posted May 8, 2006 Author Share Posted May 8, 2006 No, the stock plug wires work fine. One of mine lost it's grip on the plug; which means I must have damaged it when pressing it onto the plug. My last tank of gas ran noticably further before the light came on. And, I didn't run any less harder than before. I'll keep my eye on it but I'm wondering if the camel p#ss we get for gase in socal just got changed to it's sumertime blend. Dennis Link to comment
