jjpen Posted July 14, 2020 Share Posted July 14, 2020 Does anyone know if the mirrors from a hexhead will work on a camhead if I add the ball shaped studs for it to snap onto? Link to comment
dirtrider Posted July 14, 2020 Share Posted July 14, 2020 9 minutes ago, jjpen said: Does anyone know if the mirrors from a hexhead will work on a camhead if I add the ball shaped studs for it to snap onto? Afternoon jjpen I do not know but you might try calling Beemer Boneyard as they are pretty darn helpful. Link to comment
jjpen Posted August 14, 2020 Author Share Posted August 14, 2020 The answer is YES they will fit. Link to comment
Pappy35 Posted August 15, 2020 Share Posted August 15, 2020 I don't know if the differences matter in regards to whether they fit or not, but the Hexhead (2005-2009) and the Camhead (2010-2013) RTs have different part numbers for all those parts (even the mirrors themselves). I know the Hex assemblies had a strap and the Cams don't, so maybe that's the only way they differ. Just be advised that the parts numbers ARE different and so they might not fit. Link to comment
6speedTi Posted August 15, 2020 Share Posted August 15, 2020 As stated by another poster, the Camhead does bolt on vs the earlier hexhead just snaps into place. Unless you have both on hand and try it out it will be hit and miss. I'm sure someone might have come across this and hopefully they will chime in. Link to comment
jjpen Posted August 19, 2020 Author Share Posted August 19, 2020 (edited) you must have the 2 extra spherical studs to make it work. Edited August 19, 2020 by jjpen you must have the 2 extra spherical studs(per mirror) to make it work. Link to comment
