smiller Posted May 5, 2006 Share Posted May 5, 2006 Does anyone know the value (in ohms) of the CO potentiometer for the R1100's? TIA, Link to comment
Clive Liddell Posted May 9, 2006 Share Posted May 9, 2006 I'm a bit behind - but herewith your CO pot value... The full resistance is 990 Ohms and 14 turns of the adjuster slides the moving contact from one side to the other. Link to comment
smiller Posted May 9, 2006 Author Share Posted May 9, 2006 Ah, thanks so much Clive. That info was not easy to find. Link to comment
bmwmick Posted May 10, 2006 Share Posted May 10, 2006 I'm a bit behind - but herewith your CO pot value... The full resistance is 990 Ohms and 14 turns of the adjuster slides the moving contact from one side to the other. Clive, What are the limits? Does it go all the way to 0? I went through ALL my Rob Lentini notes and could NOT find the low limit. Thanks, Mick Link to comment
Clive Liddell Posted May 11, 2006 Share Posted May 11, 2006 Mick, You have caught me out doing a half job at documenting my findings. I recall checking R at the extremities but cannot recall whether it was zero or a residual amount. I think I would have noted it had it been other than zero but at the time I was more interested in the number of turns of the adjuster. Sorry about that... Link to comment
bmwmick Posted May 11, 2006 Share Posted May 11, 2006 Mick, You have caught me out doing a half job at documenting my findings. I recall checking R at the extremities but cannot recall whether it was zero or a residual amount. I think I would have noted it had it been other than zero but at the time I was more interested in the number of turns of the adjuster. Sorry about that... Clive, No problem (I won't tell DATA Curry) Is your final adjustment somewhere in the middle of the range? I'm thinking we could just source a 14-turn high precision pot. to make our own CO pots if we wanted. Thanks, Mick Link to comment
