Ian m Posted June 21, 2020 Share Posted June 21, 2020 My 1997 R1100RT was running fine until April 2020 approximately 4 miles then suddenly cut out, this has happened a few times and noticed when it reached 5 bar it would die, tried starting it but would misfire. Left it for half an hour would start when cold, I've replaced the HES the coil, HT leads and spark plugs also fuel filter, can hear fuel pump working take it for a run still cuts out after 5 bar. Mechanic tested oil switch,side stand switch, he heated matronic box then started the bike. Tested the injectors left the bike idling then 3 bar cuts out, when cold it starts up puzzled Could someone think of something that's missed please I bought this RT 3 years ago with only 40,000 miles after it been left outside for over 3 years without running. Now has a few thousand added on since then. Many thanks Link to comment
dirtrider Posted June 21, 2020 Share Posted June 21, 2020 1 hour ago, Ian m said: My 1997 R1100RT was running fine until April 2020 approximately 4 miles then suddenly cut out, this has happened a few times and noticed when it reached 5 bar it would die, tried starting it but would misfire. Left it for half an hour would start when cold, I've replaced the HES the coil, HT leads and spark plugs also fuel filter, can hear fuel pump working take it for a run still cuts out after 5 bar. Mechanic tested oil switch,side stand switch, he heated matronic box then started the bike. Tested the injectors left the bike idling then 3 bar cuts out, when cold it starts up puzzled Could someone think of something that's missed please I bought this RT 3 years ago with only 40,000 miles after it been left outside for over 3 years without running. Now has a few thousand added on since then. Many thanks Morning Ian Can you give us a little more detail on what happens when it stalls & won't re-start? Can you remember what the tachometer was doing just as the engine stalled at 5 bars? Can you remember what the tachometer was doing during the re-start cranking? (This could be a big help in finding your problem). You have covered the majors so you are the at point that you will probably need check for fuel return hose flow right AFTER the hot engine stall & also test for spark right after the hot engine stall. Sometimes the tachometer function right-at-at-stall or during re-cranking can also tell us a lot about what is going on. Added: You could have something as simple as a fuse opening up when it gets hot, to the fuel pump plastic impeller slipping on the motor shaft when it gets hot, to a Motronic temperature related problem, to a small split in a high pressure fuel hose inside the fuel tank (usually the U shaped hose) when the fuel gets hot, to a wire connector/terminal temperature/resistance issue, to a temperature related TPS problem, to an o2 sensor shorting problem, to ???????? Do you get any whooshing type sound when you open the fuel filler cap after a long ride? Link to comment
Ian m Posted June 22, 2020 Author Share Posted June 22, 2020 Hi dirtrider Thanks for your help and giving me info on my problem. Started my bike today on the road for approx 3 miles when it stalled just died nothing showing up on the tachometer no fluctuations. Opened fuel filler cap no whooshing noise left bike returned an hour later started first time. Tomorrow dismantle bike remove tank and check u shape hose and connection inside and gauze. Thanks again Link to comment
dirtrider Posted June 22, 2020 Share Posted June 22, 2020 6 minutes ago, Ian m said: Hi dirtrider Thanks for your help and giving me info on my problem. Started my bike today on the road for approx 3 miles when it stalled just died nothing showing up on the tachometer no fluctuations. Opened fuel filler cap no whooshing noise left bike returned an hour later started first time. Tomorrow dismantle bike remove tank and check u shape hose and connection inside and gauze. Thanks again Evening Ian You don't have a Techlusion (aftermarket fuel controller) on that bike do you? If so those can sometimes cause similar problems. Link to comment
John M. Posted June 27, 2020 Share Posted June 27, 2020 Hi Ian, I had a 96 r1100r with this same mysterious --starts fine, runs for a few miles, then dies and wont start until it cools and time passes. It seemed to happen more the day after a rain storm. It went on over a period of months. IT IS THE HALL EFFECT SENSOR OR THE WIRES ATTACHED TO IT! GOOD LUCK Spoiler JOHN Spoiler Link to comment
dirtrider Posted June 27, 2020 Share Posted June 27, 2020 19 minutes ago, John M. said: Hi Ian, I had a 96 r1100r with this same mysterious --starts fine, runs for a few miles, then dies and wont start until it cools and time passes. It seemed to happen more the day after a rain storm. It went on over a period of months. IT IS THE HALL EFFECT SENSOR OR THE WIRES ATTACHED TO IT! GOOD LUCK Reveal hidden contents JOHN Reveal hidden contents Afternoon John Are you saying Lan has 2 bad HES sensors? According to his first post Lan replaced the HES sensor & it still had the same problem. Link to comment
John M. Posted June 27, 2020 Share Posted June 27, 2020 Hi, Good question. I can only say that after experiencing this intermittent problem more than 8 times, i replaced my HES and it was fine for 18 months; then it started to happen all over again. I replaced it once more and the problem hasn't happened again...yet, that is. (The bike has been out of commission for 2 years and i moved to an s1000xr) Link to comment
Ian m Posted July 4, 2020 Author Share Posted July 4, 2020 Hi DR Last week I removed the fuel tank and checked the u pipe on the end of the pump,all seems fine. The bike does not have a Techlution on it. Could I remove the connector for the side stand switch temporarily, go for a few miles to check out. Would this cause any damage to the bike? Thank you. Link to comment
Ian m Posted July 4, 2020 Author Share Posted July 4, 2020 Hi John m, Yes I have just replaced the Hall Effect Sensor with a brand new one. Intermittent fault is hard to diagnose ! Thanks for your help Link to comment
