John Ranalletta Posted June 2, 2020 Share Posted June 2, 2020 This was a recurring issue. I'd start Basecamp and connect the GPS to the laptop via usb but Basecamp could not "see" the GPS. Occasionally, after 5-10, the GPS would connect. Connecting the GPS to the laptop and rebooting the laptop, then starting Basecamp seems to work more often than not. YMMV Link to comment
dirtrider Posted June 2, 2020 Share Posted June 2, 2020 14 minutes ago, John Ranalletta said: This was a recurring issue. I'd start Basecamp and connect the GPS to the laptop via usb but Basecamp could not "see" the GPS. Occasionally, after 5-10, the GPS would connect. Connecting the GPS to the laptop and rebooting the laptop, then starting Basecamp seems to work more often than not. YMMV Morning John If Garmin Express is running in the background then sometimes BaseCamp won't see it as the GPS is already communicating with another program. Maybe try setting Garmin Express so it doesn't run all the time in the background to see if that makes a difference. You might also go to this link & update, or re-install, the Garmin drivers. https://support.garmin.com/en-US/?faq=jAD9zCOUod0dDU55paUE99 Link to comment
Id's_OK Posted June 2, 2020 Share Posted June 2, 2020 Hey John, You might also try another USB cable. I've always found the Garmin very finicky about the connector used. Good luck! 1 Link to comment
John Ranalletta Posted June 2, 2020 Author Share Posted June 2, 2020 15 minutes ago, Id's_OK said: Hey John, You might also try another USB cable. I've always found the Garmin very finicky about the connector used. Good luck! Thanks. Tried a half dozen or so. Link to comment
John Ranalletta Posted June 2, 2020 Author Share Posted June 2, 2020 1 hour ago, dirtrider said: Morning John If Garmin Express is running in the background then sometimes BaseCamp won't see it as the GPS is already communicating with another program. Maybe try setting Garmin Express so it doesn't run all the time in the background to see if that makes a difference. You might also go to this link & update, or re-install, the Garmin drivers. https://support.garmin.com/en-US/?faq=jAD9zCOUod0dDU55paUE99 thanks, DR Link to comment
Bill_Walker Posted June 4, 2020 Share Posted June 4, 2020 On my Mac, my older Garmins/NAVs (NAV II, Zumo 660, Oregon 450) would connect right away. My NAV VI can take several minutes. Link to comment
Scarecrow Posted June 5, 2020 Share Posted June 5, 2020 not sure if this will help, but I always connect the gps first and wait for my pc to recognize that it there. Only after I can see it (usually as 2 folders, one for the garmin and one for the sd card inside it) do I then bring up basecamp. Link to comment
Sandlapper Posted June 9, 2020 Share Posted June 9, 2020 Got a Garmin 595 and sometimes it'll take a minute or so to connect Link to comment
