easybeeks Posted May 30, 2020 Share Posted May 30, 2020 I just bought a 2004 R1150RT with 58,000 Km (36,000 miles) and the previous owner, who owned it for 2 years, told me that the guy he bought it from advised him that the ABS was either disabled or removed, but my previous owner didn't remember which it was. All visible parts of the ABS are there, the ABS warning lights on the dash don't come on at all. Where is the control unit located? I want the ABS to work ! What is the difference between 'disabling' the ABS versus 'removing' the ABS completely. I think it was just disabled. What should I be looking at get the ABS functioning? Link to comment
dirtrider Posted May 31, 2020 Share Posted May 31, 2020 13 hours ago, easybeeks said: I just bought a 2004 R1150RT with 58,000 Km (36,000 miles) and the previous owner, who owned it for 2 years, told me that the guy he bought it from advised him that the ABS was either disabled or removed, but my previous owner didn't remember which it was. All visible parts of the ABS are there, the ABS warning lights on the dash don't come on at all. Where is the control unit located? I want the ABS to work ! What is the difference between 'disabling' the ABS versus 'removing' the ABS completely. I think it was just disabled. What should I be looking at get the ABS functioning? Morning easybeeks There are 2 places that operate the dash ABS lights. One is the ABS relay in the fuse box & the other is directly from the ABS module (located in front of the battery). This is how they are able to flash alternately. To get the ABS functioning you need to first verify that the ABS module is still mounted on the motorcycle and that the brake lines still go to (into & out of) the ABS module. If you have decent feeling brakes now then the ABS module has more than likely been removed, or at least by-passed. If the ABS module is still in the brake system but powered down you have very sluggish feeling brake application from both front lever or rear pedal. The ABS module is usually removed (or by-passed) due to EXPENSIVE internal issues so even if you get it plumbed back in there is a real good chance that you will then have to remove it & send it out for repair. So first try to locate the ABS module, (larger) module in front of the battery with brake line fittings on top. If you find it then see if the brake lines still go into & out of it. If you find it then we can work from there. Link to comment
easybeeks Posted May 31, 2020 Author Share Posted May 31, 2020 Thanks so much. So will this require the gas tank to be removed in order to locate the ABS module to ascertain whether it has been removed? If so how difficult is it to remove? I have all the plastic removed as a I am doing some other maintenance. Link to comment
dirtrider Posted May 31, 2020 Share Posted May 31, 2020 8 minutes ago, easybeeks said: Thanks so much. So will this require the gas tank to be removed in order to locate the ABS module to ascertain whether it has been removed? If so how difficult is it to remove? I have all the plastic removed as a I am doing some other maintenance. Morning easybeeks You can probably see if you have it without removing the tank but you will definitely have to remove (or at least lift rear of tank) to see much of the ABS module or see if the brake lines are still running into/out of it. Look up in front of the battery. Link to comment
Brucifer1150 Posted May 31, 2020 Share Posted May 31, 2020 Would it be possible/easier to see if the rear brake line was re-routed? If I remember the procedure correctly, you run a rear GS line directly to the rear cylinder. Link to comment
dirtrider Posted May 31, 2020 Share Posted May 31, 2020 37 minutes ago, Brucifer1150 said: Would it be possible/easier to see if the rear brake line was re-routed? If I remember the procedure correctly, you run a rear GS line directly to the rear cylinder. Morning Brucifer1150 That only tells him IF the ABS module has been by-passed not if the ABS module has been removed from the motorcycle. Link to comment
easybeeks Posted June 1, 2020 Author Share Posted June 1, 2020 Without having to take the Tank off I looked on the left side in front of the battery to discover a gaping empty hole where I think the ABS Pressure Modulator on Integral ABS models, which my 2004 R1150RT is, should live. In the Clymer manual on page 603, figure 145 the picture shows the Pressure Modulator which is missing on my bike. So I guess I have no ABS !! If you tell me how to post a picture of this hole I will do so. Link to comment
Brucifer1150 Posted June 1, 2020 Share Posted June 1, 2020 1 hour ago, easybeeks said: Without having to take the Tank off I looked on the left side in front of the battery to discover a gaping empty hole where I think the ABS Pressure Modulator on Integral ABS models, which my 2004 R1150RT is, should live. In the Clymer manual on page 603, figure 145 the picture shows the Pressure Modulator which is missing on my bike. So I guess I have no ABS !! If you tell me how to post a picture of this hole I will do so. At least for me (on Windows and Firefox), when I quoted you, there is a paperclip icon under the text window. Next to it is "Drag files here to attach, or choose files... Max total size 14.65MB " Clicking on the link should bring up a new window that will allow you to choose a picture from you computer. You might have to navigate to the right folder where you store your pictures. Here is an oil thread pic: Link to comment
easybeeks Posted June 1, 2020 Author Share Posted June 1, 2020 39 minutes ago, Brucifer1150 said: At least for me (on Windows and Firefox), when I quoted you, there is a paperclip icon under the text window. Next to it is "Drag files here to attach, or choose files... Max total size 14.65MB " Clicking on the link should bring up a new window that will allow you to choose a picture from you computer. You might have to navigate to the right folder where you store your pictures. Here is an oil thread pic: Link to comment
RogerC60 Posted June 1, 2020 Share Posted June 1, 2020 That looks to me like most of the iABS module is gone, but part is still there, plugged into that large black connector. This is exactly what I did to my '03 R1150RT: removed the defective brick that contains the pumps, valves, etc. and left the electronic control module, which controls the functioning of the tail and brake lights. It appears that your electronics module is wrapped with black tape. If you don't hear a continual once-per-second clicking coming from the fuse box, it's almost certain the ABS relay has been removed from there. That would take care of one of the two red ABS lights in the dashboard. Link to comment
easybeeks Posted June 2, 2020 Author Share Posted June 2, 2020 Thanks to all for the help and education on my "new" 2004 R1150RT and the ABS issue. Have also discovered that the Charcoal cannister has been removed. Link to comment
