dduelin Posted May 15, 2020 Share Posted May 15, 2020 I just did my second oil change on my new-to-me 2007 RT. The first one I put 4 quarts even in the sump and during the 6000 mile OCI the oil level glass usually read 1/2 to 3/4 full after parking first on the side stand then a few minutes later putting it up on the center stand. This last time I put in 4 quarts and 6 oz oil as that is approximately the 4 liters the sump capacity calls for. The oil level glass shows no air space at all checking as above. Hot, first on the side stand a few minutes then up on the center stand. I think the engine might be a tiny bit overfilled but not enough to worry about? Link to comment
Rinkydink Posted May 15, 2020 Share Posted May 15, 2020 The amount of oil you put in equals approx 4 liters (providing you’re sure your math/measurements are correct). There should not be a problem if you changed the oil filter too. You could remove some of it if it really bothers you. I personally would just keep an eye on it and ride it. Link to comment
RTJohn Posted May 15, 2020 Share Posted May 15, 2020 I wouldn't remove any oil. The manual calls for 4 liters of oil during an oil change. The level will be slightly above the sight glass for a bit. It's not overfilled. Link to comment
Rougarou Posted May 15, 2020 Share Posted May 15, 2020 I just do four quarts and let it go Link to comment
dduelin Posted May 15, 2020 Author Share Posted May 15, 2020 I did replace the filter. Thanks for the replies. I'm going riding. 3 Link to comment
