MBensonNC Posted April 29, 2006 Share Posted April 29, 2006 I'm trying to post a picture of the HES on my 2002 1150RT. I'm not sure what to make of it other than it looks BAD. I removed the HES, took the wire wrapping off, and tested the sensor which seemed to be working fine. I stripped the wire housing, too, and the wire within looked OK. After replacing the HES (and alternator belt), the bike ran fine during a quick test ride. Has anyone seen an HES with wire wrapping like this before? Is wire wrapping between the upper and lower sensors typical? Link to comment
ShovelStrokeEd Posted April 29, 2006 Share Posted April 29, 2006 That is yugly. Sure hope it looks better now. Link to comment
powerman Posted April 29, 2006 Share Posted April 29, 2006 i wonder how that got so cooked? Link to comment
MBensonNC Posted April 30, 2006 Author Share Posted April 30, 2006 Yes, it does look better now because I removed all of that cooked wire. I believe at one point the wire had insulation judging from the non-metalic toast I could separate from the wire. I'm just curious how / why wire was wrapped between the sensors in a way where the wire actually contacted the spinning thingy in the middle. For a novice wrench like me, this was a scarey sight. Link to comment
smiller Posted April 30, 2006 Share Posted April 30, 2006 Is wire wrapping between the upper and lower sensors typical?Absolutely not, the HES wiring is all located behind the mounting plate. It looks like what you are seeing is some kind of foreign object but I can't imagine how it got in there! Link to comment
