wbw6cos Posted March 15, 2020 Share Posted March 15, 2020 The bike is nearing the sevice interval for12,000 miles and one of the items on the schedule to check is the valve clearance. Does it matter if the motor is cold or not? I was always under the impression to have the engine cold to adjust vavles, but I doubt any adjustments will need to be done as they are just checking clearance. This issue will determine if I ride it in to the shop or bring it on my trailer on the day of the service appointment. I suppose I could always try to drop it off the day before. Thanks for any input. Link to comment
TEWKS Posted March 15, 2020 Share Posted March 15, 2020 On the older hexheads the answer would be cold. Assume the same for new bikes but DR would be the guy I’d like to hear from. Link to comment
MikeB60 Posted March 15, 2020 Share Posted March 15, 2020 You can ride it in. They will put a fan on it and get started on other stuff while it cools down. I wouldn't worry about it. You can also ride it down to Columbus and I can coach you through it. I've got a lift and "this ultimate set of tools!" Link to comment
wbw6cos Posted March 15, 2020 Author Share Posted March 15, 2020 Columbus?? I think I know where that is, or close to it anyway. Thanks for the input guys. Exactly what I was thinking. I got some riding to do. Even with my 9.5 mile commute, I will want it serviced before START. 39 days and a wake up. 1 Link to comment
PadG Posted March 16, 2020 Share Posted March 16, 2020 It will be very close to cold by the time that they get to check the valve clearance! When I do the 12k service, I would take the bike out and ride until it's hot, come back in and immediately drain the oil. Then take the valve covers off and get rid of the oil in there. Then drain and refill the FD oil' Next, is to walk away for an hour or more to allow the engine oil to drain completely, before coming back to button everything up, with the valve covers being last, and that's when I do the valve clearance check. Link to comment
wbw6cos Posted March 16, 2020 Author Share Posted March 16, 2020 Good to know. Thanks PadG! Link to comment
Ponch Posted March 20, 2020 Share Posted March 20, 2020 On my old RT, I'd ride on Friday and when I get home, dump the oil. leave it drain over night and do the valves the next morning. At that point it's dead cold. Link to comment
