REVz Posted April 28, 2006 Share Posted April 28, 2006 It appears I am ready for a neutral switch. I understand that the swingarm must be removed to replace the neutral switch. I will have the switch replaced eventually. Right now even with clutch engaged bike will not start. So I am left a lot of times, in nautical terms, "underway with no way on", ie., drifting. I have done a search on disabling the Clutch switch but not finding a very accurate description of this procedure. Could someone point out procedure to disable clutch switch and/or link to same? Thanks in advance this board is great... Link to comment
bmwmick Posted April 28, 2006 Share Posted April 28, 2006 http://bmwsporttouring.com/ubbthreads/sh...true#Post495715 All you need to do is cut the wires going to the interlock switch on the left lever and short them together. ALWAYS disengage the clutch when starting. HTH, Mick Link to comment
