Mrclubike Posted January 6, 2020 Share Posted January 6, 2020 Hello Everyone Thought I would show off my new volt meter I installed in place of the clock Here are pictures of the bracket and terminal install on a VDO meter Of course the wiring has to be modified to send a switched signal so it shuts off The clock wire could be switch in the fuse panel at the #2 fuse or you can switch it over at the the connector under the front of the Petrol tank I have an extra load shedding relay under the tank where the ABS unit would live so i concocted it up to it The lower Eclip needs to be install back into its grove so the retaining bolt has something to locate it vertically The VDO VM has a calibration hole in the side of it in case you want to tweak it to compensate for voltage drop in the circuit Link to comment
