strataj
Time
strataj
My bike didn't self update the time after the change back to standard time.  I check the menu by going into user to make sure GPS time was selected.  The Nav V is working and interfaces with the bike Wonderwheeel ie change page and receives GPS voice commands.  Any ideas?
Share this post
Link to post
Share on other sites
dirtrider
Afternoon  strataj
What time does you GPS show. If the GPS isn't outside to get a good look at the sky then it can't lock onto the satellites & update itself.
Share this post
Link to post
strataj
4 minutes ago, dirtrider said:
Afternoon  strataj
Hi DR.
It's an hour ahead and yes I've taken the bike for a nice ride, no time update. The GPS show correct time.  I'm had my 14R1200RT since February 2014, it's always updated on it's own.  It has been a great feature even keeping correct time when I've changed time zone.
Share this post
Link to post
dirtrider
19 minutes ago, strataj said:
Hi DR.
Afternoon strataj
You might re-verify that you are set to__   Accept GPS time and GPS date from the built-in navigation system (On)
Share this post
Link to post
strataj
43 minutes ago, dirtrider said:
Afternoon strataj
Thanks DR, I've done this I guess I'll update the time manually and see what happens when DST starts
Best
Share this post
Link to post
ExGMan
I just went out for a ride for the first time since the switch to standard time. My 2015RT is also stuck in Daylight time.  Nav shows the correct time, but bike shows an hour later.
Share this post
Link to post
PatM
I had the same issue. I played with the time settings in my Nav V and somehow the bike switched to the proper time.
Share this post
Link to post
WBinDE
A thread on a different forum points to the Nav V as the culprit, either it doesn't recognize the change or it doesn't communicate it to the bike.
It couldn't hurt to be sure your Nav is updated through Garmin Express, there may be a firmware update that fixes it. Take the opportunity to download & install the latest map updates too, current is 2020.20
Share this post
Link to post
dirtrider
Afternoon WBinDE
Current NT map is 2020.3_
Share this post
Link to post
WBinDE
Just now, dirtrider said:
Afternoon WBinDE
Wow, I just hooked up to Basecamp a couple of weeks ago and it didn't offer to upgrade me. Thanks for the info.
Share this post
Link to post
ExGMan
I've got 2020.30 as the current. Maybe that's the problem?
Share this post
Link to post
strataj
One of the guys in my local club keeps us posted on all updates, I'm current.  I did look at the GPS setting earlier won't hurt to play with them.
Share this post
Link to post
strataj
I wouldn't think so that's just the map.  It could would be a firmware issue, if so I hope an update is coming soon.
Share this post
Link to post
dirtrider
Afternoon strataj
You might try a computer hook up as all my GPS units just got a small time zone update. It covered a lot of countries & areas but I didn't see the U.S. as one of the added time zone updates. (still maybe)
Share this post
Link to post
Paul De
Pretty depressing right now with all the cold and snow we are getting in the upper mid west I'll just leave the time to DST, prolly because it will be the correct time before I get to ride again!
Share this post
Link to post
Bill Spurgeon
I am having a problem with the time also.  If you go into the Apps on the Nav V and check the date on the World Clock.  If it is wrong, it is the firm ware of the GPS.
I contacted Garmin and they are aware of the problem and are working on a fix.  If you call then and let them know you have the problem, they will put you on their list to be notified when the fix is done.  My understanding of it is that it all comes from the year 2000 switch over on the clocks or something like that.
Bill
Share this post
Link to post
MachineJoe
Bill,  Thanks for posting this. I hope you are misunderstanding what they were trying to say because the "year 2000 switchover" took place 19 years ago.   :ohboy:
Not good for Garmin
Share this post
Link to post
dirtrider
Not good for Garmin
Morning Joe
Read this__
https://support.garmin.com/ms-MY/?faq=zWQY6Z2kFiAuY9kDnDBgZ6
Share this post
Link to post
PatM
I'm not sure this has a direct relation with the year 2000 roll over. My Nav V worked fine until I did the 2020.30 update.
IMO it may be an indirect relation as in  they pushed a fix for all device and broke ours.
I've sent an email to Garmin to and got this reply:
Quote
Hello Patrick,
Thanks for choosing Garmin.  I am going to have to add you to a case we have created to investigate this issue. I apologize but we do not have a time frame on a resolution for this issue.
Charles
Product Support
Garmin International
For 24-hour access to support videos, manuals, FAQs & more, visit the Support Center.
Share this post
Link to post
hefy_jefy
Wow! a bug, I have the exact same problem, spent an hour or so resetting defaults on the bike, clearing the NAV 5 memory etc etc.
Should have looked here first!!!  I will email Garmin support...
Share this post
Link to post
Bill_Walker
FWIW, I didn't have any problem with my up-to-date NAV VI.  However, I did have the unit on while it was off the bike after the DST change, so the GPS already had the correct time before the bike was fired up.  That may matter.
Share this post
Link to post
JamesW
OMG!  That cooks it for me no wethead in my future if no automatic time change from daylight to standard.  Maybe time to start a class action lawsuit?
Share this post
Link to post
Bernie
My 2018 RT and Nav6 changed from Daylight Saving to Standard time with no problems.
It did require for me to install the Nav 6 on the bike and then start the bike and let the Nav6 boot up fully.
Maybe it helps to keep your Nav6 updated? Of course that is not possible automatically.
Of course I am sure your local dealer will gladly update your Nav6 for you.
Share this post
Link to post
strataj
Garmin has the fix out, it's available via Garmin Express.  My Wethead now updates the time to the bike correctly and the date is correct in the Nav V.
Share this post
Link to post
