Michaelr11 Posted October 10, 2019 Share Posted October 10, 2019 No, in my opinion. Looks like the bike is secured while resting on the side stand-should not be. Bike should be upright, with front wheel preferably in a chock or pressed against a block or wall. Straps from the frame going forward from the forks and backwards from rear subframe applying pressure on the suspension so that the bike stays upright and doesn’t bounce or rock back and forth. 1 Link to comment
wbw6cos Posted October 10, 2019 Share Posted October 10, 2019 It looks secure enough.....................for a parts bike, that is. 1 Link to comment
Rougarou Posted October 10, 2019 Share Posted October 10, 2019 If the trip was completed and the bike did not fall off or have damage, yes, it was secured correctly no matter how unconventional it looks. Would I have done it that way, nah,.....not at all, but I also use cups on the grips as a primary hooking point on the front end, which to many here are a no-no. 1 Link to comment
szurszewski Posted October 10, 2019 Share Posted October 10, 2019 You forgot to strap down the tank and the windshield which obviously fell off the trailer. Fortunately you did get a couple of straps to the top case rack, which is the strongest point in the LT. 1 1 Link to comment
Calvin (no socks) Posted October 10, 2019 Share Posted October 10, 2019 Does this strap make my butt look big? 1 Link to comment
Joe Frickin' Friday Posted October 11, 2019 Share Posted October 11, 2019 That bike's got some battle damage. I'm guessing some of those straps (e.g. the one over the topcase) are there to hold down parts that might otherwise fall off while moving down the highway. Link to comment
