Marty Hill Posted September 23, 2019 Share Posted September 23, 2019 (edited) 700gs/9k miles Triangle in upper left. Red then yellow after a minute or so. Bright then off. Blue light below then off in a few moments. It got me home. Any thoughts? Thanks! Edited September 23, 2019 by Marty Hill added info Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 Curious, is this not seen by dirt rider or others? Link to comment
Skywagon Posted September 25, 2019 Share Posted September 25, 2019 Hi Marty...if you are asking if we can see your post...I can.. I have no clue though to your question. I'm sure DR will respond shortly. 1 Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 My post seems to have been deleted. I'm thrilled! Link to comment
dirtrider Posted September 25, 2019 Share Posted September 25, 2019 On 9/23/2019 at 10:19 AM, Marty Hill said: 700gs/9k miles Triangle in upper left. Red then yellow after a minute or so. Bright then off. Blue light below then off in a few moments. It got me home. Any thoughts? Thanks! Afternoon Marty I did in fact miss it, this forum is off the bottom of my viewing screen so if I don't think to scroll down once in a while I just don't see it. In any case we will need more info-- does the triangle have a partial circle around it? (denotes ASC). Does the problem still appear? If not then maybe you inadvertently pushed the ACS deactivation button on the L/H handlebar pod. (maybe try that button while moving to see if it duplicates what you saw). Look in your riders manual (around page 50) as that tells you a little about it. I presume that you are referring to light (2) & light (1) ? Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 Yes light 1 and 2. 1. is shaped small on left to larger on right with exclamation inside. 2. abs is flashing, Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 No partial circle around abs. Link to comment
dirtrider Posted September 25, 2019 Share Posted September 25, 2019 4 minutes ago, Marty Hill said: No partial circle around abs. Afternoon Marty So your 700 doesn't have ACS? Is the problem still there? If not then_____ Look in your riders manual around page 49 for ABS disable, then see if disabling your ABS duplicates your light flashing. If problem is still there then you will probably need a GS-911 or dealers computer to see what brake code or codes are stored. Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 ACS? UPPER LEFT TRIANGLE WITH EXCLAMATION INSIDE. ABS FLASHING. First problem I've ever had just prior to leaving for weekend BMW get together in NC. Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 Think I'll head to the dealer. Thanks! Marty Link to comment
dirtrider Posted September 25, 2019 Share Posted September 25, 2019 18 minutes ago, Marty Hill said: ACS? UPPER LEFT TRIANGLE WITH EXCLAMATION INSIDE. ABS FLASHING. First problem I've ever had just prior to leaving for weekend BMW get together in NC. Afternoon Marty Triangle with exclamation inside only = ABS Triangle with exclamation inside with partial circle around it = ABS & ASC Link to comment
Marty Hill Posted September 25, 2019 Author Share Posted September 25, 2019 Lucky me, I've got both. Can't complain tho. 200k on 12gs's and 1 flat tire. First problem on 7gs's with about 18k total on both. Need to find a friend with truck/trailer. Thanks for all your info. Link to comment
