MoteroNC Posted September 20, 2019 Share Posted September 20, 2019 On my 09 r1200rt after some recent maintenance I had an incident where the bolts back out and the caliper came loose from the disc plate. I find it very strange that both bolts would come out and the caliper body but it did happen. Just to make sure I am doing this correctly these bolts are meant to install dry (no loctite) and at a 24 Nm? Appreciate any advice. Link to comment
dirtrider Posted September 20, 2019 Share Posted September 20, 2019 48 minutes ago, MoteroNC said: On my 09 r1200rt after some recent maintenance I had an incident where the bolts back out and the caliper came loose from the disc plate. I find it very strange that both bolts would come out and the caliper body but it did happen. Just to make sure I am doing this correctly these bolts are meant to install dry (no loctite) and at a 24 Nm? Appreciate any advice. Afternoon MoteroNC That is what the manual says, 24nm, personally I use a little blue Lock-Tite on those bolts as I have found them loose on a few 1200 bikes in the past. Link to comment
MoteroNC Posted September 20, 2019 Author Share Posted September 20, 2019 Thank you. Maybe that is why they came out. Link to comment
