granpita Posted April 21, 2006 Share Posted April 21, 2006 What would cause my clock to apparently reset itself to 00:00 when it's been sitting over a few days? Battery is fine and the bike starts right up - temp, fuel and gear indicator seem OK. I'm not sure exactly when it happens but the last couple of times out, it will be 00:15 or somesuch coinciding with my ride time when I first notice it. Thank you Link to comment
Paul Mihalka Posted April 21, 2006 Share Posted April 21, 2006 The clock resetting to zero is typical of getting a momentary low voltage when you start the motor. I would think your battery or it's connections are not fine. Link to comment
Jophus Posted April 21, 2006 Share Posted April 21, 2006 Had the same problem just before the battery went kaput. Starting amperage was enough draw to bring the voltage temporarily below the clock chip's necessary voltage. May be time to consider a battery replacement on a rainy day. Link to comment
DEF Posted April 21, 2006 Share Posted April 21, 2006 The clock resetting to zero is typical of getting a momentary low voltage when you start the motor. I would think your battery or it's connections are not fine. Paul is correct. I would remove and thoroughly service the battery. Clean it and fill it to the marks with DI water. Then charge it...for about 3-4 hours at about 1 A/hr rate. Then install it making sure the connections are clean and snug. Finally before starting the bike for the first time, connect a VOM and observe voltage as you spin the starter. Voltage under load should not go below 11 VDC. Link to comment
granpita Posted April 21, 2006 Author Share Posted April 21, 2006 Thanks, Guys. I appreciate your input. Think I'll pick up a new battery - this one's the original. Link to comment
