HuskyMick Posted April 19, 2006 Share Posted April 19, 2006 Can someone please tell me how to turn the tickover up on an 05 1200 rt ? Link to comment
Albert Posted April 19, 2006 Share Posted April 19, 2006 Can someone please tell me how to turn the tickover up on an 05 1200 rt ? Well I can't help technically but, since I once ate bangers and mash in Chippenham one evening, I'll attempt to translate to West Pond English. I believe you're asking about increasing the idle speed. Correct? Link to comment
HuskyMick Posted April 19, 2006 Author Share Posted April 19, 2006 That is correct.thank you Link to comment
ChrisA Posted April 19, 2006 Share Posted April 19, 2006 I also cannot answer, but my idle speed is about 1100, which is what is recommended. Is yours running much lower than that? I can check the repair manual if you need me to. PM me and I can send you something tonight. Link to comment
HuskyMick Posted April 19, 2006 Author Share Posted April 19, 2006 It's not much it's low (1050rpm) but is very lumpy and shaking much more than mormal. it's done 20'000 miles so it not a run in thing. I have checked the manual does not say a thing. Just wanted to raise the tickover a bit to see if it would sort it out. Link to comment
cjmkerns Posted April 20, 2006 Share Posted April 20, 2006 Husky, Have you checked your plugs? Idle speed and balance, by my limited understanding, is pretty much handled by the bypass air stepper motors. Could lumpy idle be a plug issue? Carl Link to comment
