GordonB Posted July 3, 2019 Share Posted July 3, 2019 While hard to diagnose over internet, I thought I'd put it out there. 67,000 miles on my 2012RT. I recently noticed (more so on first start up), the clutch area is making a loose/rattling noise (kinda like the Ducati in neutral) It only occurs while in neutral. Pull the clutch lever in and it goes away. Symptom not as prevalent with a warmed engine but does exist. No shift issues no slippage. Clutch fluid changed out 6K ago. Fluid level okay, not full to top but slightly less. Someone suggested clutch basket and weakening springs? Link to comment
dirtrider Posted July 3, 2019 Share Posted July 3, 2019 24 minutes ago, GordonB said: While hard to diagnose over internet, I thought I'd put it out there. 67,000 miles on my 2012RT. I recently noticed (more so on first start up), the clutch area is making a loose/rattling noise (kinda like the Ducati in neutral) It only occurs while in neutral. Pull the clutch lever in and it goes away. Symptom not as prevalent with a warmed engine but does exist. No shift issues no slippage. Clutch fluid changed out 6K ago. Fluid level okay, not full to top but slightly less. Someone suggested clutch basket and weakening springs? Afternoon GordonB Not much to go on but it just might be a normal neutral gear rattle (does it go away when you raise the engine RPM's slightly?) Your 2012 1200RT bike doesn't have a clutch basket. The clutch parts on the 2012 can rattle but usually not with the clutch engaged as with clutch engaged all the clutch parts are spring loaded tight. Link to comment
GordonB Posted July 4, 2019 Author Share Posted July 4, 2019 Happy Fourth!, I started bike cold (no ear plugs) startling loud and rattling could feel the vibrations up the handle bars. Rise with slight increase in RPMs in Neutral. Up on center stand dropped into first and still prevalent. Pull in clutch all is gone. Do not feel vibrations when on the ground and moving forward in first. 50-75% less once bike is warmed up. This was a night and day change not a gradual build up. Three 350 mile days allowing bike to warm up while getting gear on (42F) each morning, then day four it all started. Link to comment
dirtrider Posted July 4, 2019 Share Posted July 4, 2019 10 minutes ago, GordonB said: Happy Fourth!, I started bike cold (no ear plugs) startling loud and rattling could feel the vibrations up the handle bars. Rise with slight increase in RPMs in Neutral. Up on center stand dropped into first and still prevalent. Pull in clutch all is gone. Do not feel vibrations when on the ground and moving forward in first. 50-75% less once bike is warmed up. This was a night and day change not a gradual build up. Three 350 mile days allowing bike to warm up while getting gear on (42F) each morning, then day four it all started. Evening GordonB This does sound more serious than just common neutral gear rattle. With noise going away with clutch dis-engaged it most likely is from clutch pack or transmission area. The sudden appearance does make it sound more serious. Can you feel anything in the clutch lever with it very slightly pulled in? (not disengaging clutch but just a little lever pressure) Without hearing or experiencing the noise it is extremely difficult to tell you much over the internet. My suggestion is to ride by your BMW dealer & have them take a listen.. Link to comment
GordonB Posted July 5, 2019 Author Share Posted July 5, 2019 Thx, trip to dealer today or tomorrow. No sensation in clutch lever and friction zone in normal range. Link to comment
