MoteroNC Posted April 13, 2019 Share Posted April 13, 2019 Would appreciate if anyone knows the part number of the screw that holds the front caliper pads in place. Mine have some surface corrosion and would like to buy replacement. This is itemized item 3 on the manual instructions for a 09 1200rt front brake pad replacement procedure. Link to comment
dirtrider Posted April 13, 2019 Share Posted April 13, 2019 45 minutes ago, MoteroNC said: Would appreciate if anyone knows the part number of the screw that holds the front caliper pads in place. Mine have some surface corrosion and would like to buy replacement. This is itemized item 3 on the manual instructions for a 09 1200rt front brake pad replacement procedure. Afternoon MoteroNC I don't think that you can buy only the bolt as it comes as a kit (not cheap) MOUNTING PARTS SET Qty (2) Part # 34 11 7 660 850 Price ea. $29.79 Link to comment
MoteroNC Posted April 13, 2019 Author Share Posted April 13, 2019 thanks DR. Will stop by dealer and check it out Link to comment
