johnlt Posted April 4, 2019 Share Posted April 4, 2019 I have a set of Denali lights including driving lights and tail lights. After 6 months of use with no problem, they just quit working. I spoke with Denali and they said I probably needed a firmware update. Whoda thunk you needed to update firmware for your light to work. I downloaded the update and wa-la, they work again. Times are changing!! Link to comment
Claudio Posted April 6, 2019 Share Posted April 6, 2019 Very interesting. I just put a set on our GS's using a canSmart unit. From what I saw of the light harness, I didn't think there was a usb-port/connector anywhere on it. Was it the data dim device that had the firmware or is there some other controller with your lights? Link to comment
JR356 Posted April 21, 2019 Share Posted April 21, 2019 I do not have the CanSmart module for direct comparison,but the Hex EzCan from which it is based has a USB port on the module itself,to allow for programming,upgrades. JR356 Link to comment
Claudio Posted April 22, 2019 Share Posted April 22, 2019 The basic Denali light kit would not have the CanSmart (a rebranded version of the EzCan). The original post indicated a light failure but I don't think he indicated the presence of the controller. A needed firmware update would likely not cause a light failure, I'd suspect a wiring issue. Link to comment
JR356 Posted April 23, 2019 Share Posted April 23, 2019 Hi, The lights themselves have no update option that I have ever seen,only the CanSmart controller is firmware upgradeable via USB port. Yes the OP does not specify,but he states he has a full system including brake light,so I am guessing he has an integrated system with CanSmart controller. The OP can hopefully chime in and tell us how he upgraded. JR356 Link to comment
