Motobricker Posted March 21, 2019 Share Posted March 21, 2019 I got a great deal on factory driving lights for my 2018 RTW. I have Twisted Throttle mounts under the mirrors, already have a set of small driving light mounted there, but they are on a HEXeCam wiring. Has anyone added factory lights to the RTW and do I need to get a new Left hand switch in order to make them work or rather light up the dashboard signal? I could simply just hook them up to my existing wiring, but was hoping for a more factory install. Link to comment
Bighopper Posted March 22, 2019 Share Posted March 22, 2019 If you want them to work via the factory install then you will have to have them turned on by the dealer via a software update. I would go with your HEXecam, you have more options on how they would work. Link to comment
JR356 Posted March 24, 2019 Share Posted March 24, 2019 Hi, You likely have a second light channel left on the EzCan for a second set of lights,or the system can be configured that way. To find out,you need to hook up the ExCan module via USB cable to a laptop and look at the configuration. The Hex website as well as probably some youtube videos will show the process. Going the factory route will likely be big $$ install. JR356 Link to comment
strataj Posted March 24, 2019 Share Posted March 24, 2019 I installed the factory lights when I purchased the bike 2/2014, it's an easy job. I did need to have the dealer activate the lights, this was done during a software update without a fee. A connection is behind the left painted panel that's all you know to know the rest is very easy kit to install. I had zero instructions. If you need instructions its on the BMW repair manual CD. Jay Link to comment
Motobricker Posted March 25, 2019 Author Share Posted March 25, 2019 5 hours ago, strataj said: I installed the factory lights when I purchased the bike 2/2014, it's an easy job. I did need to have the dealer activate the lights, this was done during a software update without a fee. A connection is behind the left painted panel that's all you know to know the rest is very easy kit to install. I had zero instructions. If you need instructions its on the BMW repair manual CD. Jay Did you have to get a new left handlebar switch with the button to turn them on or did they just work with lights?? Link to comment
strataj Posted March 25, 2019 Share Posted March 25, 2019 It was in the kit, http://www.realoem.com/bmw/enUS/showparts?id=0A13-USA-01-2014-K52-BMW-R_1200_RT_0A03,_0A13_&diagId=77_0680 you'll see it listed, you can buy it. Jay Link to comment
