Automag Posted March 17, 2019 Share Posted March 17, 2019 So, I bought a ‘95 RSL. I’ve always thought they were a great looking bike, and I liked the way it rode. It had under 30k miles, and ran nicely. It has dual exhausts... other than the visual symmetry of the duals on a twin, I’m seeing (and hearing) few advantages. Am I missing something, or was this an answer to a question no one asked? Link to comment
dirtrider Posted March 17, 2019 Share Posted March 17, 2019 5 hours ago, Automag said: So, I bought a ‘95 RSL. I’ve always thought they were a great looking bike, and I liked the way it rode. It had under 30k miles, and ran nicely. It has dual exhausts... other than the visual symmetry of the duals on a twin, I’m seeing (and hearing) few advantages. Am I missing something, or was this an answer to a question no one asked? Morning Automag It is basically "an answer to a question no one usually asks", no power gain & more than likely a slight power loss as well as a tuning issue due to exhaust reversion concerns. Having dual isolate pipes means the single o2 sensor will only read off of one cylinder so that is a problem as the Motronic can only process (1) o2 sensor input. So if using independent pipes it really should have the o2 sensor input eliminated. (assuming a US motorcycle) Unless very low pipes with small or limited (re loud) mufflers then dual exhausts probably preclude using side panniers. If you like the looks & it runs OK at light throttle then no big problems (but probably no performance gain & more than likely some performance loss, especially at lower throttle openings). The (remote) exhaust sound is probably not the best as the BMW boxer is a 360° firing opposed twin & those have terrible firing pulses to make sound decent without a significant camshaft improvement & higher compression. On the BMW 360° boxer engine, you can easily make them loud, but it is 'very difficult' to make them sound pleasing (especially at a distance) There is a reason that you see very few BMW (2) cylinder boxers with aftermarket exhausts & see even fewer with any sort of dual pipe conversions. Now if it had a 90° engine configuration that would be a different story. Link to comment
Jerry Duke Posted March 17, 2019 Share Posted March 17, 2019 A friend had a set. It came with a performance chip. After 50+ years of two mufflers on airheads it looked right for the new oilhead, just wasn't worth the price I guess. Link to comment
Automag Posted March 17, 2019 Author Share Posted March 17, 2019 Dirtrider and Jerry Duke- Thank you. The bike does actually go to a single pipe off the headers with an O2 sensor, and then Ys to a separate cans. The luggage does fortunately fit. I’d just never seen another set like this on an RS/RSL. I didn’t think there was any advantage, so I guess someone just wanted to be different (though there is possibly a weight gain). Thank you again. Auto Link to comment
dirtrider Posted March 17, 2019 Share Posted March 17, 2019 3 minutes ago, Automag said: Dirtrider and Jerry Duke- Thank you. The bike does actually go to a single pipe off the headers with an O2 sensor, and then Ys to a separate cans. The luggage does fortunately fit. I’d just never seen another set like this on an RS/RSL. I didn’t think there was any advantage, so I guess someone just wanted to be different (though there is possibly a weight gain). Thank you again. Auto Afternoon Auto With it having a Y pipe then that sounds like a decent system. I would like to see what it looks like it on the bike, can you post a picture? Link to comment
JamesW Posted March 17, 2019 Share Posted March 17, 2019 Dual exhaust on an RSL?? Now, I would like to see a picture of that. Link to comment
Automag Posted March 17, 2019 Author Share Posted March 17, 2019 Dirtrider and Jerry Duke- Thank you. The bike does actually go to a single pipe off the headers with an O2 sensor, and then Ys to a separate cans. The luggage does fortunately fit. I’d just never seen another set like this on an RS/RSL. I didn’t think there was any advantage, so I guess someone just wanted to be different (though there is possibly a weight gain). Thank you again. Link to comment
Automag Posted March 17, 2019 Author Share Posted March 17, 2019 It does make it easier to find in the vast sea of black RSLs... 1 Link to comment
dirtrider Posted March 17, 2019 Share Posted March 17, 2019 24 minutes ago, Automag said: Dirtrider and Jerry Duke- Thank you. The bike does actually go to a single pipe off the headers with an O2 sensor, and then Ys to a separate cans. The luggage does fortunately fit. I’d just never seen another set like this on an RS/RSL. I didn’t think there was any advantage, so I guess someone just wanted to be different (though there is possibly a weight gain). Thank you again. Evening Auto Pretty good looking system, seems to fit the look of the bike nicely. Link to comment
Paul De Posted March 18, 2019 Share Posted March 18, 2019 Thanks for sharing. I've never seen that aftermarket kit and really like the look. A high quality kit for sure, Link to comment
Automag Posted March 19, 2019 Author Share Posted March 19, 2019 Thank you. It does appear to be well built- though it’s not labeled by the maker...makes me wonder if it might be one of the RB exhausts, or the copy version of the RB that someone supposedly made for a bit...dunno. Link to comment
Jerry Duke Posted March 19, 2019 Share Posted March 19, 2019 I believe it was Luftmeister. Here's about the only info I could find. https://bikez.com/msgboard/msg.php?str_id=12309&type=bike&id=766 Link to comment
Jerry Duke Posted March 19, 2019 Share Posted March 19, 2019 Here's one on Ebay. https://www.ebay.com/itm/1994-Bmw-R1100rs-Full-Exhaust-System-Headers-Pipe-Muffler-Luftmeister-/292539507365?_trksid=p2385738.m4383.l4275.c10 Link to comment
Automag Posted March 20, 2019 Author Share Posted March 20, 2019 Jerry Thank you. I’ve been puzzled, as it is not labeled. I know RB originally built some stuff for Luftmeister...and this looks nicely made. Thank you again. Link to comment
Automag Posted March 22, 2019 Author Share Posted March 22, 2019 Mr. Behn at RB responded to my query (I’d sent him an email with a photo). This exhaust is an RB exhaust, built for Luftmeister back in the day. Thank you all for the pointers. This board is populated by an amazing group of people. Link to comment
kcteun Posted April 14, 2019 Share Posted April 14, 2019 Can you describe the sound and volume? I have a staintune on my R11S and love the noise. I wouldn't mind the luftmeister on eBay but don't want it to sound like a ducati with a race muffler. Link to comment
Automag Posted June 9, 2019 Author Share Posted June 9, 2019 Kcteun, Apologies for for not replying earlier. The bike with the duals is loud. Not horrible at speed, but quite noticeable in town. It is a bit throaty, but no one is going to mistake it for a Duc, or a Harley, for that matter. I don’t think I would have done it, had they not been on the bike when I bought it. Link to comment
