Spokane2303 Posted March 8, 2019 Share Posted March 8, 2019 Does anyone know if putting one of these on my 2004 R1150RT will work or will it mess with the computer's monitoring the rear tail light function? Link to comment
RPG Posted March 8, 2019 Share Posted March 8, 2019 https://vololights.com/products/vololights-enhanced-motorcycle-visibility Link to comment
Spokane2303 Posted March 8, 2019 Author Share Posted March 8, 2019 Interesting option; but, their site says "sold out"!I currently have a Backoff modulator from a previous bike. So, for now $$$, I want to know if I can safely use it? Thanks! Link to comment
Paul De Posted March 8, 2019 Share Posted March 8, 2019 I went with the Kissan Tech tailblazer on my R1100RT but says it also works on the 2004 1150 as well ~$70. Been using it for 15 years no problems and I have not heard of issues with compatibility on the1150. It is as plug and play as changing the brake light bulb. Flashes about 5 times then goes solid on while braking Link to comment
dirtrider Posted March 8, 2019 Share Posted March 8, 2019 41 minutes ago, Spokane2303 said: Does anyone know if putting one of these on my 2004 R1150RT will it work or will it mess with the computer's monitoring the rear tail light function? Afternoon Spokane2303 It very well could effect the ABS module's ability to correctly monitor the rear tail light for function. It probably won't effect it enough to cause a serious problem but it might effect it enough so the ABS module can't tell that the tail light has burnt out so it might not bring the brake light on at low power in place of the tail light then light the dash warning. If this happens then you will probably have to verify tail light function manually (just like the old days!) Link to comment
Spokane2303 Posted March 26, 2019 Author Share Posted March 26, 2019 Anyone try the Hyperlites brake lights? LED's that attach on the sides of the license plate. They look brite! Hoping they will not mess with the ABS brake light monitoring function?? Link to comment
dirtrider Posted March 26, 2019 Share Posted March 26, 2019 17 minutes ago, Spokane2303 said: Anyone try the Hyperlites brake lights? LED's that attach on the sides of the license plate. They look brite! Hoping they will not mess with the ABS brake light monitoring function?? Morning Spokane2303 As long those are wired up properly & the stock incandescent rear bulb remains in the system then they usually don't cause any issues. Link to comment
Skywagon Posted March 26, 2019 Share Posted March 26, 2019 These will do the trick...you can get just brake, brake and turn, brake, turn, and run....You can have them go solid or blink...a little pricey but I have had them on 3 BMW bikes including this RT LC. They come with complete instructions that are accurate and correct. They splice into the proper circuits with positaps which came in my kit. https://hyperlites.com/ Link to comment
Spokane2303 Posted March 26, 2019 Author Share Posted March 26, 2019 Purchased a set of Hyperlites this afternoon. Will report on how they install and work once received. Thanks to all! Link to comment
MarinPhil Posted April 13, 2019 Share Posted April 13, 2019 Hyperlites on my 11RT , no issues. Link to comment
kioolt Posted April 13, 2019 Share Posted April 13, 2019 I've been running Hyperlites on my 04 RT for almost 14 years now. I actually have two sets on the bike. Link to comment
