GordonB Posted March 7, 2019 Share Posted March 7, 2019 I've noticed a bit of sluggish starting typical of a weak battery. So, Fully charged then checked voltage. approx 12.75 at rest (analog gauge ), drops just below 10 at crank/startup. 10 seems a bit low to me. Thoughts? and Thanks. Link to comment
dirtrider Posted March 7, 2019 Share Posted March 7, 2019 11 hours ago, GordonB said: I've noticed a bit of sluggish starting typical of a weak battery. So, Fully charged then checked voltage. approx 12.75 at rest (analog gauge ), drops just below 10 at crank/startup. 10 seems a bit low to me. Thoughts? and Thanks. Morning GordonB The 12.75 fully charged doesn't tell us much UNLESS that voltage was taken a good 12 hours AFTER the battery charging. If you measured the static voltage right after charging then you were reading the surface charge & that is pretty meaningless.___ (also, when measuring static motorcycle battery voltage, a tenth or two on the battery's fully-charged voltage can make a BIG difference in battery health so you really should use a quality digital voltmeter to measure accurately) As for the just under 10v cranking?-- That is borderline BUT without qualifying it might be close to normal. A very cold engine with thick heavy engine oil, trans in neutral but clutch lever not pulled in might give you that number. Under 10v cranking on a recently ridden motorcycle would be low. About the only real test of your battery is to have a Load-Test done (a lot of motorcycle dealers will do that for free). Even a load test won't always tell you everything but if it fails the load test then you are probably looking at a new battery. Are you using the PROPER battery charger for your battery (especially if charging it in cold conditions)? A lot of older trickle chargers or maintainer type chargers are not correct for the newer AGM type battery's & will under charge them (especially in cold ambient conditions). Or, if your battery is 3 or more years old just replace it as a good starting point. Link to comment
Pappy35 Posted March 7, 2019 Share Posted March 7, 2019 I got a couple of slow sluggish (as in barely turning over) starts recently even after having my bike plugged into a Optimate 4 which I thought was unusual. I looked through the records I got when I bought the bike and saw that the battery, a Scorpion, was a little over three years old so I just opted to replace it with a Yuasa. This is the one I got and it was $90 shipped. No more sluggish starts. For items like this that are not very expensive and can leave you stranded I will more often than not just replace them with new and not expend the effort of trying to diagnose them. Link to comment
BarnRat Posted March 7, 2019 Share Posted March 7, 2019 Just because a trickle battery charger (tender) will show that the battery is fully charged, how it behaves under a load, like starting, is the final decision maker. But try to clean your battery connections -- it may help. Link to comment
GordonB Posted March 7, 2019 Author Share Posted March 7, 2019 Thanks all. 12.75v taken after 48 hours of charging and sitting in garage no riding. (too much rain here). Charged with BMW charger. Battery in 3 years old (BMW Gel) Cold start 60F. I typically trade out at 4 years, but may do this one at 3. I will do a test with a warm start, just to be sure. Link to comment
dirtrider Posted March 7, 2019 Share Posted March 7, 2019 4 hours ago, GordonB said: Thanks all. 12.75v taken after 48 hours of charging and sitting in garage no riding. (too much rain here). Charged with BMW charger. Battery in 3 years old (BMW Gel) Cold start 60F. I typically trade out at 4 years, but may do this one at 3. I will do a test with a warm start, just to be sure. Afternoon GordonB I have seen a LOT of the BMW Gel battery's die at or near the 3 year mark (at least drop in performance enough to lower cranking voltage to below 10 volts). If you plan on going anyplace far from home, or far from help then a new AGM type battery would be a highly suggested purchase. Those BMW Gel battery's can have a sudden death, like start fine one time then not the next time (usually on the same ride). My 3 year old oem BMW Gel in my 1200RT died on me when stuck in stop & go traffic on a 95°f+ day in the L/H lane of a 4 lane freeway. I was VERY lucky in that a van about 3 vehicles back had a group of teenagers in it, they stepped right up & pushed me off fast enough to get a rolling bump start. (unfortunately I never got their names to thank them). Link to comment
Pappy35 Posted March 7, 2019 Share Posted March 7, 2019 41 minutes ago, dirtrider said: Afternoon GordonB I have seen a LOT of the BMW Gel battery's die at or near the 3 year mark <snip> This is consistent with my bike's history. One of the previous owners replaced the OEM battery about 2-3 years after the bike was initially sold and then I changed it almost three years later. Link to comment
BarnRat Posted March 7, 2019 Share Posted March 7, 2019 Yep, 3-4 years on an acid battery (AGM or otherwise). Here in the desert it's closer to 3 years. Heat can damage a battery but cold will only lessen the battery's efficiency -- unless in severe cold where the acid/water mix freezes. Link to comment
GordonB Posted March 7, 2019 Author Share Posted March 7, 2019 Thanks all. I always er to the side of caution. New battery time. Link to comment
BarnRat Posted March 8, 2019 Share Posted March 8, 2019 1 minute ago, GordonB said: Thanks all. I always er to the side of caution. New battery time. Is your battery easy to get to? Some of these older oilheads, especially my R1100S, is a real pain to access the battery -- tucked up under the tupperware and tank. Link to comment
Pappy35 Posted March 8, 2019 Share Posted March 8, 2019 Camhead batteries are right there under the front seat support. One T25 screw releases the hold down, disconnect the leads, put a couple of zip ties through the holes and lift straight up (don't need the zips, that just changes it from simple to dead simple). 1 Link to comment
Tri750 Posted March 14, 2019 Share Posted March 14, 2019 On 3/7/2019 at 7:16 PM, Pappy35 said: Camhead batteries are right there under the front seat support. One T25 screw releases the hold down, disconnect the leads, put a couple of zip ties through the holes and lift straight up (don't need the zips, that just changes it from simple to dead simple). Replacing the screw with a Phillips head of the same size helps if one is ever on the road or on the side of the road needing a battery and tools are limited. Also, to remove the battery, nabbing the negative post on the battery with Vice Grips and clamping down works well too. Link to comment
Pappy35 Posted March 14, 2019 Share Posted March 14, 2019 3 hours ago, Tri750 said: Replacing the screw with a Phillips head of the same size helps if one is ever on the road or on the side of the road needing a battery and tools are limited. Also, to remove the battery, nabbing the negative post on the battery with Vice Grips and clamping down works well too. I always have a small tool kit with me but regardless, that's a good idea. It's easy to get the battery out but easier with a couple of zip ties (I keep about 10 in my tool kit). Link to comment
