The Fabricator Posted February 27, 2019 Share Posted February 27, 2019 R1150GS. I replaced the left cam chain tensioner. I had to remove the swing arm bolt to lift the swing arm. I have read many posts and seen 1 video about replacing this tensioner and always assumed it came right out with out moving the swing arm. Am I missing something? Link to comment
AndyS Posted February 27, 2019 Share Posted February 27, 2019 Good day, I am not sure what your question is. To replace the tensioner you only need to remove the tank and then you have access to the tensioner in front of the LH throttle body. Do you mean you want to change the LH camchain guide? Please can you explain more. Link to comment
dirtrider Posted February 27, 2019 Share Posted February 27, 2019 9 hours ago, The Fabricator said: R1150GS. I replaced the left cam chain tensioner. I had to remove the swing arm bolt to lift the swing arm. I have read many posts and seen 1 video about replacing this tensioner and always assumed it came right out with out moving the swing arm. Am I missing something? Morning The Fabricator I guess that is one way to do it but seems like a LOT of extra work. Bet you were working with the bike on the center stand? The BMW (GS) is slightly tighter to get out than on the (R) or (RT) due to slight front suspension differences. Those posts that you read & the videos that you watched were probably for the (R) or (RT) not the (GS). I haven't ever had to remove the front front trailing arm (swing arm) bolt to get the L/H tensioner out of the GS but I do tie the bike down tight on my lift so the front suspension compresses, that usually moves the front trailing arm up 'just' enough to clear the tensioner (barely). Or if no bike lift handy I put bike on center stand for most pre-removal work then drop bike on to side stand to get the tensioner out (or just use a couple of ratchet straps to collapse the front suspension enough to clear the tensioner removal). Link to comment
szurszewski Posted February 27, 2019 Share Posted February 27, 2019 Are you talking about the front suspension? Here’s a link to an earlier thread on this site. It has a link or two that might helpful, or you can google oilhead cam chain tensioner upgrade and find a couple of good, quick videos. Link to comment
CNred Posted February 27, 2019 Share Posted February 27, 2019 I just finished replacing my Cam Chain Tensioner on a 2003 R1150rtp. It was pretty tight to get at and remove, but I was able to get it our and replaced without removing any suspension parts. I had to unscrew the tensioner then, with a small screw driver compress the spring inside to be albe to remove the assembly. Once that housing and spring were remove the bottom piece was easily removed with a small magnet. It was a tight process, and at one point I thought I was going to have to remove the swing arm. At the end of thr day it was not necessary. Link to comment
AndyS Posted February 27, 2019 Share Posted February 27, 2019 Ah, I get it, you guys don't mean the swinging arm, you mean the front Telelever training arm. So, no, you don't have to (and don't want to) be removing this. The parts are all accessible without disturbing any of that stuff. IF you have removed the nut and withdrawn the axle, you may have to get someone else to jiggle that front end to allow the spindle to align. So, to the O.P. yes you are missing something. You may need to use deep reach socket and also a flexible socket extension to get the correct angle. Make sure that bolt is done up correctly against the aluminium crush washer - OR - you will have an oil leak. Link to comment
dan cata Posted February 28, 2019 Share Posted February 28, 2019 No need to remove it, slide out the top part, then the spring,then using a magnet, pick up the bottom piston. Install in reverse order Dan. 1 Link to comment
dirtrider Posted February 28, 2019 Share Posted February 28, 2019 1 hour ago, dan cata said: No need to remove it, slide out the top part, then the spring,then using a magnet, pick up the bottom piston. Install in reverse order Dan. Morning Dan On the OP's 1150 GS it usually isn't that simple as the GS usually needs just a bit more clearance at the trailing arm. Also, on the GS I usually have to fool with the spring a bit before the top part will come out. (the GS is a bit more fiddly than the R or RT, at least on US bikes anyhow) Link to comment
Claudio Posted March 1, 2019 Share Posted March 1, 2019 Definitely didn't need to mess with the front suspension. In my case I modified a box wrench (cut a chunk out of the arm) to create more access to the tensioner and simply compressed the front suspension on my lift (thereby creating a bit more clearance to lift out the old tensioner and put in the new one). Link to comment
