Stormy60 Posted April 10, 2006 Share Posted April 10, 2006 Has anyone installed the CQ Light/HID headlights on the R1200RT? Good price but I wonder if the R1200RT wiring is heavy enough to carry the start up load, as it has no relay switch and no power leads to the battery. Are there any issues with the Cambus system? What are some of the others anyone may have installed themselves? Where did you get them? Link to comment
Survived-til-now Posted April 11, 2006 Share Posted April 11, 2006 Sorry , no answer but I'd like to jump on your bandwagon on HID in the hope of clarifying some things. I think I am right in believing, from previous threads, that you have to wire the HID and associated ballasts direct from the battery and use a relay linked to the headlight circuit(s) to switch them on? In which case you have to fit a resistor in the relay circuit to simulate the load on the headlight cicuits or the CANBUS thinks the bulbs have blown and keeps warning you about it......... Sounds like the "lower power demand" that is a feature of HID actually turns out to be a lot more because of the need for the resistors.... unless you can tolerate a flashing warning on the dash..... And all this on a bike that already seems to have a bit too much load on the alternator with a small battery It all seems too much messing about but perhaps someone who has done this exercise can tell both of us how its done and that there isn't a hidden penalty in power drain? Please...... Link to comment
Stormy60 Posted April 11, 2006 Author Share Posted April 11, 2006 I put HID on my LT and loved it. That installation required the relay and had direct wires to the battery. It also had a trigger wire. QC Light said when I e-mailed them theirs works on the existing wiring. It has a ballast for each bulb. It gets its power from the bulb wires. On the LT web site a bunch of guys are installing them and are having no problems with them. The LT does not have the Cambus system. H-7 is about $200. Check it out at http://www.cqlight.ca Link to comment
Dirtmerchant Posted April 11, 2006 Share Posted April 11, 2006 I put the cqhids on my R12GS in both high and low beams. They work great, plug and play without any issues on mine. Link to comment
ScottT Posted April 12, 2006 Share Posted April 12, 2006 Uh Stormy, there is no such thing as "Cambus". It is CAN-bus. Controller Area Network, hence the CAN acronym. Link to comment
Stormy60 Posted April 12, 2006 Author Share Posted April 12, 2006 Thanks for the reply. Does your GS have the CAN-bus system? If it does I think I will try it. Link to comment
steve539 Posted April 12, 2006 Share Posted April 12, 2006 I direct wired an HID (6000 Calvin) to replace my stock H7 high beam on an 05 R1200 RT with no problems with the canbus system. Love it. It can be undone and system returned to stock (although I can't imagine why) if desired. Check out www.bikelitez.com Link to comment
