jpvic Posted April 9, 2006 Share Posted April 9, 2006 since my bike came with a "rider's manual," and not an "owner's manual," i'm lacking some basic info. can anyone tell my the fluid types and amounts for an 03 k1200rs? specifically, i need gearbox, rear drive, and forks. thanks. john Link to comment
JerryMather Posted April 9, 2006 Share Posted April 9, 2006 From BMW Service & Technical Booklet for a 98 KRS: Transmission Oil: Brand - name hypoid gear oil, API class GL5 0.85 quarts Rear wheel drive: 0.24 quarts Viscosity class @ outside temp. Above 41 F - SAE 90 Below 41 F - SAE 90 alternatively - SAE 80 W 90 Link to comment
ShovelStrokeEd Posted April 10, 2006 Share Posted April 10, 2006 I have had really good luck with Mobil 1 full synthetic gear oil SAE 75w140 in my BMW transmissions and final drives. Quantities as above. I don't think the fork oil much matters. Somebody else will have to come up with a quantity but any 5 or 10w fork oil should work, it is only there to keep the seals lubricated. When you drain the leg, measure what came out and replace with a like quantity. Link to comment
Bruce C Posted April 10, 2006 Share Posted April 10, 2006 510cc per leg on the forks. Bruce C Link to comment
hANNAbONE Posted April 11, 2006 Share Posted April 11, 2006 i'M uSING "RedLine Shockproof" oil in my rear drive and tranny. Mobil 1 // or // Amsoil 15-50 in my crankcase Link to comment
Rich06FJR1300 Posted April 16, 2006 Share Posted April 16, 2006 i use redline in my tranny but not in the final drive. I've had problems with it foaming and spewing out of the vent. Link to comment
rdfrantz Posted April 16, 2006 Share Posted April 16, 2006 i use redline in my tranny but not in the final drive. I've had problems with it foaming and spewing out of the vent. I suggest thou needst look into that. Redline is great stuff (like much else out there), and anything akin to the proper quantity of 75W-140 GEAR oil shouldn't be foaming in a normally configured and operating Final Drive. Even for an FJR1300 which only holds a cup of the stuff. Best wishes. Link to comment
JerryMather Posted April 17, 2006 Share Posted April 17, 2006 As much as I liked Redline, I to was having the same problem with it coming out of my vent when I used it in my RT. I was cleaning the stuff off the wheel more times than I wanted. I checked the vent for blockage a few times and never saw anything wrong with it and always filled the drive up to the correct level. Link to comment
