RAMBLIN RED Posted January 28, 2019 Share Posted January 28, 2019 Windshield adj. stopped suddenly. Seems the four exposed pivot pins were far to stiff and caused the nylon worm drive gear to strip. So, parts on order, but I did not see any limit switches to limit travel and I wonder how this is accomplished. Also, does anyone know where to position the arms for a start point? 2000 R11RT Link to comment
dirtrider Posted January 28, 2019 Share Posted January 28, 2019 9 minutes ago, RAMBLIN RED said: Windshield adj. stopped suddenly. Seems the four exposed pivot pins were far to stiff and caused the nylon worm drive gear to strip. So, parts on order, but I did not see any limit switches to limit travel and I wonder how this is accomplished. Also, does anyone know where to position the arms for a start point? 2000 R11RT Morning RAMBLIN RED The limit switches are inside the motor assembly. I haven't seen any specific info on re-timing the limits to the axle position. I'm pretty sure that someone has done a write-up on re-timing (someplace). I haven't done one in quite a while now but on the ones that I have done long ago I cheated as I had another (unmolested) motor assembly here to match the timing up to. If you can't find anything on timing then you will probably have to take a few assembly tries until you get it timed correctly. Link to comment
AndyS Posted January 28, 2019 Share Posted January 28, 2019 27 minutes ago, RAMBLIN RED said: ...Seems the four exposed pivot pins were far to stiff and caused the nylon worm drive gear to strip. .... Are you sure? These elements normally do not represent 'that much' resistance. I would have a close look over the whole mechanism. Trying to motor the screen down with something jammed in the gap may cause the problem. Link to comment
RAMBLIN RED Posted January 28, 2019 Author Share Posted January 28, 2019 1 hour ago, AndyS said: Are you sure? These elements normally do not represent 'that much' resistance. I would have a close look over the whole mechanism. Trying to motor the screen down with something jammed in the gap may cause the problem. Andy, they were so stiff I used penetrating oil over two days to loosen two of them, then after bracing the arms I used a drift punch to drive them out. I think it is the salt air where I live. Link to comment
AndyS Posted January 28, 2019 Share Posted January 28, 2019 Oh dear. Sorry to hear that. Link to comment
