Bud Posted October 17, 2018 Share Posted October 17, 2018 Anyone have any idea???? I've put it on a battery charger for now so the battery doesn't go flat. Thanks in advance for the correct answer!!!! Link to comment
Jim Moore Posted October 17, 2018 Share Posted October 17, 2018 I'll bet there's a relay in the fuse box. You'll be able to feel in click. Pull it out. Link to comment
PatML Posted October 17, 2018 Share Posted October 17, 2018 Hi Bud, Did you hit the hazard button? Red one with a triangle. Are all four flashing, or all four on permanently? Do they stay on even if you key off the ignition? (Sounds like yes if you have had to put it on the battery charger.) Link to comment
Bud Posted October 17, 2018 Author Share Posted October 17, 2018 OLD PHART BRAIN FREEZE :facepalm: NEVER MIND :dopeslap: I'm just going to slink away for a while till the laughing ends. :cry: Link to comment
nrp Posted October 17, 2018 Share Posted October 17, 2018 Re-boot up the system by disconnecting the battery for 30 minutes. Link to comment
szurszewski Posted October 17, 2018 Share Posted October 17, 2018 Sometime I'll tell you the story of the time I stripped almost the entire fuel system off my snowmachine, in the middle of an Alaskan night - wouldn't start after a “tip over” .... the punch line is after thirty or so minutes laura says, are you sure the key is on? It looks slightly crooked to me.... Link to comment
Bud Posted October 17, 2018 Author Share Posted October 17, 2018 I guess I had never in my life turned on the 4 way flashers. I kept hitting the button over and over again but they wouldn't turn off. :dopeslap: Remember that saying about doing the same thing and expecting different results????????? Went inside, wrote the post, went back outside and pondered for a while, then, in a fit of exasperation I hit the turn signal cancel button. Viola I hope, at the very least, I provided some levity for a few members today. Link to comment
tallman Posted October 17, 2018 Share Posted October 17, 2018 Re-boot up the system by disconnecting theowner for 30 minutes. Link to comment
Stan Walker Posted October 18, 2018 Share Posted October 18, 2018 I hope, at the very least, I provided some levity for a few members today. You did indeed make me smile..... Stan Link to comment
Bud Posted October 18, 2018 Author Share Posted October 18, 2018 Re-boot up the system by disconnecting theowner for 30 minutes. Sometimes a need a good re-boot! Link to comment
