Cohiba54 Posted October 16, 2018 Share Posted October 16, 2018 2015 R1200RT +/- 19000 miles, 18000 mile service not done yet. Electronic start failed on first attempt but kicked off just fine on second attempt. That has happened a couple of times over the past two weeks, other than that no other problems on start up. On the way home, stop at a traffic light had several warning lights in the dash come on and the bike died. Tried electronic start but only had the small red light blink a few times and no computer check sequence. Has anyone had this happen? Link to comment
alegerlotz Posted October 16, 2018 Share Posted October 16, 2018 Check your battery connections, especially the ground. Link to comment
reg26 Posted October 16, 2018 Share Posted October 16, 2018 Also check your Key Fob battery. I'm on my third one on my 2015 RT Link to comment
Cohiba54 Posted October 16, 2018 Author Share Posted October 16, 2018 Also check your Key Fob battery. I'm on my third one on my 2015 RT I always look at the fob battery check at startup and it was at half. But I'll replace it anyways and give it a try this evening. Link to comment
Cohiba54 Posted October 16, 2018 Author Share Posted October 16, 2018 Check your battery connections, especially the ground. I'll check that out this evening. Link to comment
LittleBriar Posted October 16, 2018 Share Posted October 16, 2018 Also check your Key Fob battery. I'm on my third one on my 2015 RT I always look at the fob battery check at startup and it was at half. But I'll replace it anyways and give it a try this evening. Hmm... Didn't know you can check key fob battery level. Will have to dig out the manual. Link to comment
Cohiba54 Posted October 16, 2018 Author Share Posted October 16, 2018 Also check your Key Fob battery. I'm on my third one on my 2015 RT I always look at the fob battery check at startup and it was at half. But I'll replace it anyways and give it a try this evening. Hmm... Didn't know you can check key fob battery level. Will have to dig out the manual. Yep there will be a "KEY" icon that lights up on the dash as the computer checks the bikes systems. Link to comment
KSB Posted October 17, 2018 Share Posted October 17, 2018 2015 R1200RT +/- 19000 miles, 18000 mile service not done yet. Electronic start failed on first attempt but kicked off just fine on second attempt. That has happened a couple of times over the past two weeks, other than that no other problems on start up. On the way home, stop at a traffic light had several warning lights in the dash come on and the bike died. Tried electronic start but only had the small red light blink a few times and no computer check sequence. Has anyone had this happen? Start fails on first attempt, but starts on second happened to me a few times and then my battery died! Link to comment
PadG Posted October 17, 2018 Share Posted October 17, 2018 2015 R1200RT +/- 19000 miles, 18000 mile service not done yet. Electronic start failed on first attempt but kicked off just fine on second attempt. That has happened a couple of times over the past two weeks, other than that no other problems on start up. On the way home, stop at a traffic light had several warning lights in the dash come on and the bike died. Tried electronic start but only had the small red light blink a few times and no computer check sequence. Has anyone had this happen? I don't think that your issue is the key fob, even though that red light that comes on when you try to restart indicates that the bike couldn't detect a fob. If the fob battery dies while you are riding, it would NOT shut down the engine. It just won't allow you to restart. Those warning lights and the fact that the engine shut down said that the problem is elsewhere. The fob battery being weak is just a coincident. As suggested, checking the ground connection is a great advice for the first thing to look at. Link to comment
