don_k Posted September 6, 2018 Share Posted September 6, 2018 Looking for opinions and suggestions folks. I have the oversized case lids on my R1100 RT. One of the rubber bumpers on the side of the case was pulled part way off. What glue or addesive's would people recommend to reattach it with? Thanks in advance. Link to comment
AndyS Posted September 6, 2018 Share Posted September 6, 2018 I would try an Automotive Body shop. They often use a high grade weather resistant double sided tape. Link to comment
dirtrider Posted September 6, 2018 Share Posted September 6, 2018 Looking for opinions and suggestions folks. I have the oversized case lids on my R1100 RT. One of the rubber bumpers on the side of the case was pulled part way off. What glue or addesive's would people recommend to reattach it with? Thanks in advance. Afternoon don_k Personally I usually use black super weather-strip adhesive (commonly called Gorilla Snot). That weather-strip adhesive is used commercially to hold moldings, weather strips, rubber bumpers on to automobiles. Super weather-strip adhesive is not the cheapest to buy for a single usage (like your bumper) but it has MANY other uses around the home or garage. If you don't want to buy a tube yourself, then cart your case & cleaned rubber bumper to about any local auto body shop, or repair shop, as most will put a dab on your rubber bumper without charge if you ask nicely. Once you reinstall the bumper just use a piece of masking tape to hold it in place until the weather-strip adhesive dries. Link to comment
PAS Posted September 6, 2018 Share Posted September 6, 2018 A quick search shows many places to get it cheap! Super Weather strip adhesive Link to comment
elkroeger Posted September 7, 2018 Share Posted September 7, 2018 You can get 3M automotive trim adhesive tape at most auto parts stores. Or Amazon. It comes in variety of lengths and widths. Completely remove the trim piece, remove all residue of the old tape. wipe it all down with some alcohol, or soapy water. Put the tape on the back of the trim, peel up the backing, then carefully line it up... and commit. Link to comment
