RET2 Posted July 13, 2018 Share Posted July 13, 2018 Parked my 2005 RT and a week later it cranks but won't fire. Plenty of fuel, fuel pump or relay maybe? Link to comment
dirtrider Posted July 13, 2018 Share Posted July 13, 2018 Parked my 2005 RT and a week later it cranks but won't fire. Plenty of fuel, fuel pump or relay maybe? Morning RET2 No real fuel pump relay in your 1200 bike, more of a fuel pump controller. Can you hear the fuel pump run for a couple of seconds when you first turn the key on? Look on the dash when you turn the key on, anything showing, like EWS, if so then you could have a key pellet or antenna ring issue. (the early 1200 bikes had a sort-of recall/service bulletin on the antenna ring failing & causing a no-start). If you have other keys on your key chain then make sure they are not dangling down causing an interference therefore confusing the bikes anti-theft system. Does your bike have a factory or aftermarket alarm system on it??????? If so what do you have as we might have to address that as the cause. Lastly-- try holding the twist grip at about 1/8 to 1/4 open THEN try starting the engine. Link to comment
RET2 Posted July 13, 2018 Author Share Posted July 13, 2018 Thanks for the leads, I'll try to isolate and post results back Link to comment
