boxerguy Posted March 25, 2018 Share Posted March 25, 2018 Just wondering if anyone is using Amsoil 75W-90 Synthetic Gear Oil...I use this stuff in the Differentials of My Volvo Semi-Tractor and noticed I have Tons of it left from a 10 gal pail i used the last time... My 96 R1100RT calls for a 75 or 80W-90 gear lube for the Final Drive and Transmission... Is it preferable to just use a 100% petroleum based lube or would the fully synthetic Amsoil work equally or better? Walter Link to comment
dirtrider Posted March 25, 2018 Share Posted March 25, 2018 Just wondering if anyone is using Amsoil 75W-90 Synthetic Gear Oil...I use this stuff in the Differentials of My Volvo Semi-Tractor and noticed I have Tons of it left from a 10 gal pail i used the last time... My 96 R1100RT calls for a 75 or 80W-90 gear lube for the Final Drive and Transmission... Is it preferable to just use a 100% petroleum based lube or would the fully synthetic Amsoil work equally or better? Walter Afternoon Walter That Amsoil 75W-90 will work just fine in the transmission & can work in the final drive (80W-90 is very difficult to find in todays market). Not much of any gain using synthetic in the final drive on the older BMW boxer bikes (big failure point in those is the crown bearing & the synthetic part means nothing to it's life) . The down side to using some synthetic gear oil's is possible pinion seal seeping. Personally I usually use conventional gear oil in the BMW 1100 / 1150 final drives as those seem to seep less in those final drives. . Link to comment
boxerguy Posted March 25, 2018 Author Share Posted March 25, 2018 D.R. Thanks for the input..I think I'll stay with the Valvoline 80W-90 Valvoline for the Final Drive. I don't know what was used in the Tranny of this 96-r1100rt, but I think I'll go to this Amsoil Synthetic when I change the Transmission Fluid later today...I think I read somewhere that some riders got considerably reduced noises when shifting when they had switched to synthetic oils. Walter Link to comment
dirtrider Posted March 25, 2018 Share Posted March 25, 2018 D.R. Thanks for the input..I think I'll stay with the Valvoline 80W-90 Valvoline for the Final Drive. I don't know what was used in the Tranny of this 96-r1100rt, but I think I'll go to this Amsoil Synthetic when I change the Transmission Fluid later today...I think I read somewhere that some riders got considerably reduced noises when shifting when they had switched to synthetic oils. Walter Afternoon Walter The synthetic gear oil will probably make little or no difference in transmission noise but sometimes new (un- sheered) gear oil will be slightly thicker & might make a very slight difference. You might get a little better shift quality as the 1996 1100 has "O" rings on the transmission spinning gear to shaft interface to reduce neutral gear rattle & those "O" rings produced drag & hindered shift quality a little. Link to comment
SKYGZR Posted March 26, 2018 Share Posted March 26, 2018 Using it in the tranny on the RS & GT, have used it in the Diff's also, yet now have just regular gear oil in them..(I think).. Link to comment
